Hi Andrew,
In my mind, the C code will be a file containing all the functions to connect, request data stream/polling, run equipment adjustment routines, change properties and close connection. All of this is provided by the manufacturer
.so library (which I'm adding to the LIBS target of the IOC's Makefile). So, the IOC will carry
everything within itself needed to control the equipment.
What I have in mind is to add this .cpp file to the SRCS target of the IOC's Makefile, and to call all of these functions using subroutine records.
The equipment is an interferometer from SmarAct, called PicoScale.
Hi Allan,
On 11/7/18 10:47 AM, Allan Serra Braga Bugyi wrote:
> I have the need to access the record support structs inside my C code.
> What I want is to be able to access the records' fields to pass them as
> parameters to some functions. These functions are inside a dynamic
> library .so from the manufacturer. Any idea or workaround?
What is "your C code" — where is it running and what calls it? You need
to describe what you're doing it a bit more detail for us to be able to
help you as the answers will be different for different circumstances...
- Andrew
- RE: Record referencing inside device support Mark Rivers
- Record referencing inside device support Allan Serra Braga Bugyi
- Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
Re: Record referencing inside device support Allan Serra Braga Bugyi
Re: Record referencing inside device support Mooney, Tim M. via Tech-talk
<2018>
<2018>
ANJ, 07 Nov 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
