It sounds to me like it might be better to write a driver based on asynPortDriver, rather than writing device support.
Device support is more difficult because you need to understand how each record works. If you write a driver based on asynPortDriver you can use the standard asyn device support.
https://epics.anl.gov/modules/soft/asyn/R4-34/asynPortDriver.html
This is a tutorial on writing an asynPortDriver, starting from a very simple version and working up to a more complex one. This is for a Measurement Computing device using the vendor library.
https://github.com/epics-modules/measComp/blob/master/documentation/measCompTutorial.pdf
Hi Andrew,
In my mind, the C code will be a file containing all the functions to connect, request data stream/polling, run equipment adjustment routines, change properties and close connection. All of this
is provided by the manufacturer .so library (which I'm adding to the LIBS target of the IOC's Makefile). So, the IOC will carry everything within itself needed to control the equipment.
What I have in mind is to add this .cpp file to the SRCS target of the IOC's Makefile, and to call all of these functions using subroutine records.
The equipment is an interferometer from SmarAct, called PicoScale.
Hi Allan,
On 11/7/18 10:47 AM, Allan Serra Braga Bugyi wrote:
> I have the need to access the record support structs inside my C code.
> What I want is to be able to access the records' fields to pass them as
> parameters to some functions. These functions are inside a dynamic
> library .so from the manufacturer. Any idea or workaround?
What is "your C code" — where is it running and what calls it? You need
to describe what you're doing it a bit more detail for us to be able to
help you as the answers will be different for different circumstances...
- Andrew
- Record referencing inside device support Allan Serra Braga Bugyi
- Re: Record referencing inside device support Johnson, Andrew N. via Tech-talk
- FWD: Record referencing inside device support Allan Serra Braga Bugyi
Re: Current Source / Power supply suggestion David Vine
devlib2 release 2.10 Michael Davidsaver
<2018>
<2018>
ANJ, 07 Nov 2018 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
