1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: streamdevice I/O Intr
From: William Kirstaedter via Tech-talk <[email protected]>
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Fri, 30 Nov 2018 09:55:14 +0100
Hi Dirk,
the in "txx"; was only my attempt to have everything correct. (make the protocol depict reality) From a usability view the "txx" answer doesnt matter.
Wouldnt it be possible to create an opt-in to skip the input Queue? This way standard behaviour would remain as is but people like me get the opportunity to just send data wether or not there is input....
William Kirstaedter (PP&B)
Fritz-Haber-Institut der MPG
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Mail: [email protected]
Am 30.11.2018 um 08:47 schrieb Dirk Zimoch via Tech-talk:
I just see that your toggle command *does* expect a reply.
toggle {
        out "%{ETM|STM}";
        in "txx";
Thus not flushing the input queue is no solution.
On 30.11.2018 08:45, Dirk Zimoch via Tech-talk wrote:
Hi William,
To check Mark's theory please do streamReportRecord on your toggle record. If Mark is correct then it should show "active command=out".
I'm not sure what to do about it. I don't want to sacrifice handling unsolicited input. Also not cleaning the input queue is bad for protocols that have out-in protocols (that is most).
If input arrives so fast that the input queue never gets empty,
then you probably need a faster computer as the EPICS IOC cannot keep up with the traffic. It also depends on how much processing you do with the input.
Your java program probably does not care if there is input available before sending the output. That is because it knows that the command does not expect any reply. However StreamDevice cannot assume this in general. I would need to check if the 'out' command is followed by an 'in' (not necessarily immediately) and skip flushing the input queue if it isn't.
Dirk
On 29.11.2018 17:51, Mark Rivers wrote:
well I dont. I only see the start String "STM\r" but never the stop String "ETM\r"
That's what I thought.
Here is the start of code for writeHandler.  You should definitely enable debug, and see if you see these messages ("reading old input", etc.).  One possibility is that it gets stuck in that loop if the input is arriving so fast that "received" is never 0.
// now, we can write (called by asynManager)
void AsynDriverInterface::
writeHandler()
     debug("AsynDriverInterface::writeHandler(%s)\n",
         clientName());
     asynStatus status;
     size_t written = 0;
     pasynUser->timeout = 0;
     if (!pasynGpib)
     // discard any early input, but forward it to potential async records
     // thus do not use pasynOctet->flush()
     // unfortunately we cannot do this with GPIB because addressing a device as talker      // when it has nothing to say is an error. Also timeout=0 does not help here (would need
     // a change in asynGPIB), thus use flush() for GPIB.
     do {
         char buffer [256];
         size_t received = 0;
         int eomReason = 0;
         debug("AsynDriverInterface::writeHandler(%s): reading old input\n",
             clientName());
         status = pasynOctet->read(pvtOctet, pasynUser,
             buffer, sizeof(buffer), &received, &eomReason);
         if (status == asynError || received == 0) break;
#ifndef NO_TEMPORARY
         if (received) debug("AsynDriverInterface::writeHandler(%s): flushing %ld bytes: \"%s\"\n",              clientName(), (long)received, StreamBuffer(buffer, received).expand()());
#endif
     } while (status == asynSuccess);
     else
         debug("AsynDriverInterface::writeHandler(%s): flushing old input\n",
             clientName());
          pasynOctet->flush(pvtOctet, pasynUser);
     // discard any early events
     receivedEvent = 0;
     pasynUser->timeout = writeTimeout;
     // has stream already added a terminator or should
     // asyn do so?
     size_t streameoslen;
     const char* streameos = getOutTerminator(streameoslen);
     int oldeoslen = -1;
     char oldeos[16];
     if (streameos) // stream has already added eos, don't do it again in asyn
         // clear terminator for asyn
         status = pasynOctet->getOutputEos(pvtOctet,
             pasynUser, oldeos, sizeof(oldeos)-1, &oldeoslen);
         if (status != asynSuccess)
             oldeoslen = -1;
             // No EOS support?
         pasynOctet->setOutputEos(pvtOctet, pasynUser,
             NULL, 0);
     status = pasynOctet->write(pvtOctet, pasynUser,
         outputBuffer, outputSize, &written);
     debug("AsynDriverInterface::writeHandler(%s): "
         "write(..., outputSize=%ld, written=%ld) "
         "[timeout=%g sec] = %s\n",
         clientName(), (long)outputSize,  (long)written,
         pasynUser->timeout, asynStatusStr[status]);
-----Original Message-----
From: [email protected] <[email protected]> On Behalf Of William Kirstaedter via Tech-talk
Sent: Thursday, November 29, 2018 10:48 AM
To: Dirk Zimoch <[email protected]>; [email protected]
Faradayweg 4-6
14195 Berlin
Tel: 030 8413 5405
Am 29.11.2018 um 17:46 schrieb Dirk Zimoch via Tech-talk:
On 29.11.2018 17:44, Dirk Zimoch via Tech-talk wrote:
Are you seeing any error messages on the IOC console?  If the problem
is what I describe then I would expect to see queueRequest timeout
error messages.
If StreamDevice could not queue the request, he would not see the
output string in asynTrace.
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO) [General Data Protection Regulation (GDPR)] der Europaeischen Union.
Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Re: streamdevice I/O Intr William Kirstaedter via Tech-talk
Re: streamdevice I/O Intr Michael Westfall via Tech-talk
RE: streamdevice I/O Intr Mark Rivers via Tech-talk
Prev: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Next: Re: streamdevice I/O Intr Dirk Zimoch via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <2018>  2019  2020  2021  2022  2023  2024  2025  2026
ANJ, 30 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
