I am trying to build EPICS application on ARM target, and the cross compiling on host have no error,
but the IOC on the target cannot execute:
-bash: ./armexample: No such file or directory
[Ernest]:
If you are building your IOC application via the EPICS Templates, then executable is found here by default:
<TOP>/bin/<T_A>/armexample
For example, I built and application called "Jupiter" for a linux target:
<TOP>/bin/rhel6-x86_64/Jupiter
Please provide more information such as did you first create a skeleton for you app with:
makeBaseApp.pl -t example
my configuration as following:
HOST: Ubuntu 14.04 (on VMware)
TARGET: Exynos4412
BASE: base-3.14.12.5
GCC: arm-none-linux-gnueabi-gcc-4.4.1
the cross compiling configuration is:
configure/CONFIG_SITE:
CROSS_COMPILER_TARGET_ARCHS=linux-arm
CROSS_COMPILER_HOST_ARCHS=linux-x86
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
configure/os/CONFIG_SITE.Common.linux-arm:
#COMMANDLINE_LIBRARY = READLINE
configure/os/CONFIG_SITE.linux-x86.linux-arm:
GNU_DIR = /opt/armtoolchain/arm-2009q3
GNU_TARGET = arm-none-linux-gnueabi
the .bashrc configuration is:
export EPICS_HOST_ARCH=linux-x86
export EPICS_BASE=/home/control/epics/base-3.14.12.5
export LD_LIBRARY_PATH=/opt/armtoolchain/arm-2009q3/lib:$EPICS_BASE/lib/linux-arm
I am still getting the error message on target, Please solve my above query.
Thanks
Jia LIU
