On 1/12/19 6:57 PM, 刘佳 wrote:
-----原始邮件-----
发件人:"Williams Jr., Ernest L."
<[email protected]>
发送时间:2019-01-11 23:52:15 (星期五)
收件人: "刘佳"
<[email protected]>
抄送: "[email protected]"
<[email protected]>
主题: Re: Cannot execute application on ARM target
Yes, I built the IOC application via the EPICS templates:
makeBaseApp.pl -t example armexample
makeBaseApp.pl -i -t example armexample ( the architechture choose linux-arm, and the application name is armexample)
Okay, that is good.
I didn't change any configuration of the application, and then MAKE is no error. So I copy the <appTop> to the target.
In this step, I need more information:
What type of linux distro are running on your target?
What file system are you using?
Does you target do an nfs mount anywhere?
when I try to start the application on the target, ../../bin/linux-arm/armexample st.cmd,
the Error is:
-bash: ../../bin/linux-arm/armexample: No such file or directory
and then I change to the <appTop>/bin/linux-arm/,
chmod +x armexample, and ./armexample, the Error is:
-bash:
./armexample: No such file or directory
I didn't known what to do next, please give some advices, thanks a lot!
In theory, this should be working.
After you copy the <appTop> to your target file system, please do a pwd().
I would like to see the path on your target.
In general, I think we could help you troubleshoot this more efficiently if you
list all the commands you type in your console.
Cheers,
Ernesto
Jia LIU
I am trying to build EPICS application on ARM target, and the cross compiling on host have no error,
but the IOC on the target cannot execute:
-bash: ./armexample: No such file or directory
[Ernest]:
If you are building your IOC application via the EPICS Templates, then executable is found here by default:
<TOP>/bin/<T_A>/armexample
For example, I built and application called "Jupiter" for a linux target:
<TOP>/bin/rhel6-x86_64/Jupiter
Please provide more information such as did you first create a skeleton for you app with:
my configuration as following:
HOST: Ubuntu 14.04 (on VMware)
TARGET: Exynos4412
BASE: base-3.14.12.5
GCC: arm-none-linux-gnueabi-gcc-4.4.1
the cross compiling configuration is:
configure/CONFIG_SITE:
CROSS_COMPILER_TARGET_ARCHS=linux-arm
CROSS_COMPILER_HOST_ARCHS=linux-x86
SHARED_LIBRARIES=NO
STATIC_BUILD=YES
configure/os/CONFIG_SITE.Common.linux-arm:
#COMMANDLINE_LIBRARY = READLINE
configure/os/CONFIG_SITE.linux-x86.linux-arm:
GNU_DIR = /opt/armtoolchain/arm-2009q3
GNU_TARGET = arm-none-linux-gnueabi
the .bashrc configuration is:
export EPICS_HOST_ARCH=linux-x86
export EPICS_BASE=/home/control/epics/base-3.14.12.5
export LD_LIBRARY_PATH=/opt/armtoolchain/arm-2009q3/lib:$EPICS_BASE/lib/linux-arm
I am still getting the error message on target, Please solve my above query.
Thanks
Jia LIU
- Re: Cannot execute application on ARM target Jemian, Pete R. via Tech-talk
- Cannot execute application on ARM target 刘佳 via Tech-talk
- Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
- Re: Re: Cannot execute application on ARM target 刘佳 via Tech-talk
<2019>
2025
<2019>
2025
ANJ, 12 Jan 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
