1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Cannot execute application on ARM target
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
Date: Sun, 13 Jan 2019 04:40:56 +0000
Also, please report the output of this command
uname -a
On 2019-01-12 10:39 PM, Williams Jr., Ernest L. via Tech-talk wrote:
> On 1/12/19 6:57 PM, 刘佳 wrote:
>>     -----原始邮件-----
>>     *发件人:*"Williams Jr., Ernest L." <[email protected]>
>>     *发送时间:*2019-01-11 23:52:15 (星期五)
>>     *收件人:* "刘佳" <[email protected]>
>>     *抄送:* "[email protected]" <[email protected]>
>>     *主题:* Re: Cannot execute application on ARM target
>>     Yes, I built the IOC application via the EPICS templates:
>>     makeBaseApp.pl -t example armexample
>>         makeBaseApp.pl -i -t example armexample ( the architechture
>>     choose linux-arm, and the application name is armexample)
> Okay, that is good.
>>     I didn't change any configuration of the application, and then
>>     MAKE is no error. So I copy the <appTop> to the target.
> In this step, I need more information:
> What type of linux distro are running on your target?
> What file system are you using?
> Does you target do an nfs mount anywhere?
>>     when I try to start the application on the target,
>>     ../../bin/linux-arm/armexample st.cmd,    the Error is:
>>     -bash: ../../bin/linux-arm/armexample: No such file or directory
>>     and then I change to the <appTop>/bin/linux-arm/, chmod +x
>>     armexample, and./armexample, the Error is:
>>     -bash: ./armexample: No such file or directory
>>     I didn't known what to do next, please give some advices, thanks a
>>     lot!
> In theory, this should be working.
> After you copy the <appTop> to your target file system, please do a pwd().
> I would like to see the path on your target.
> In general, I think we could help you troubleshoot this more efficiently
> if you
> list all the commands you type in your console.
> Cheers,
> Ernesto
>>     Jia LIU
>>     *From:* [email protected]
>>     <[email protected]> on behalf of 刘佳 via Tech-talk
>>     <[email protected]>
>>     *Sent:* Thursday, January 10, 2019 6:59 PM
>>     *To:* [email protected]
>>     *Subject:* Cannot execute application on ARM target
>>     Hi,
>>     I am trying to build EPICS application on ARM target, and the
>>     cross compiling on host have no error,
>>     but the IOC on the target cannot execute:
>>     *[Ernest]:*
>>     *If you are building  your IOC application via the EPICS
>>     Templates, then executable is found here by default:*
>>     *<TOP>/bin/<T_A>/armexample*
>>     *For example, I built and application called "Jupiter" for a linux
>>     target:*
>>     *<TOP>/bin/rhel6-x86_64/Jupiter
>>     *Please provide more information such as did you first create a
>>     skeleton for you app with:*
>>     *makeBaseApp.pl -t example
>>     my configuration as following:
>>         HOST: Ubuntu 14.04 (on VMware)
>>         TARGET: Exynos4412
>>         BASE: base-3.14.12.5
>>         GCC: arm-none-linux-gnueabi-gcc-4.4.1
>>     the cross compiling configuration is:
>>         configure/CONFIG_SITE:
>>             CROSS_COMPILER_TARGET_ARCHS=linux-arm
>>             CROSS_COMPILER_HOST_ARCHS=linux-x86
>>             SHARED_LIBRARIES=NO
>>             STATIC_BUILD=YES
>>         configure/os/CONFIG_SITE.Common.linux-arm:
>>             #COMMANDLINE_LIBRARY = READLINE
>>         configure/os/CONFIG_SITE.linux-x86.linux-arm:
>>             GNU_DIR = /opt/armtoolchain/arm-2009q3
>>             GNU_TARGET = arm-none-linux-gnueabi
>>     the .bashrc configuration is:
>>         export EPICS_HOST_ARCH=linux-x86
>>         export EPICS_BASE=/home/control/epics/base-3.14.12.5
>>         export
>>     LD_LIBRARY_PATH=/opt/armtoolchain/arm-2009q3/lib:$EPICS_BASE/lib/linux-arm
>>     I am still getting the error message on target, Please solve my
>>     above query.
>>     Thanks
>>     Jia LIU
Pete R. Jemian, Ph.D.                 <[email protected]>
Beam line Controls and Data Acquisition (BC, aka BCDA)
Advanced Photon Source,    Argonne National Laboratory
Argonne, IL  60439                    630 - 252 - 3189
       Education is the one thing for which people
          are willing to pay yet not receive.
Cannot execute application on ARM target 刘佳 via Tech-talk
Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
Re: Re: Cannot execute application on ARM target 刘佳 via Tech-talk
Prev: Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
Next: Re: Cannot execute application on ARM target Williams Jr., Ernest L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 12 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
