Subject: |
Re: Weird stream device behavior when using the IOC shell's exit function |
Ralph Lange via Tech-talk <[email protected]> |
To: |
EPICS Tech Talk <[email protected]> |
Date: |
Tue, 5 Feb 2019 13:14:06 +0100 |
No command available which starts with asyn. I cloned the latest asyn from github with the same behavior.
That's a sign that your IOC binary was not compiled with the necessary asyn definitions in the Makefile. (Also explains why that doesn't change with another asyn version that it is _not_ using.)
Make sure the the necessary dbd snippets from asyn are included in the dbd generation for your IOC and that the asyn library is linked against. (Both usually set in the .../src/Makefile of the App that creates your IOC binary.)
Cheers, ~Ralph
- Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
- Re: Weird stream device behavior when using the IOC shell's exit function Mark Rivers via Tech-talk
- Re: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
- RE: Weird stream device behavior when using the IOC shell's exit function Mark Rivers via Tech-talk
- RE: Weird stream device behavior when using the IOC shell's exit function Abdalla Ahmad via Tech-talk
<2019>
<2019>
ANJ, 05 Feb 2019 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
