1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Subject: EK9000 Device Support
From: "Lorelli, Jeremy J via Tech-talk" <[email protected]>
Date: Thu, 19 Sep 2019 18:20:01 +0000
Hello everyone,
As my summer internship project I've been working on device support for the Beckhoff EK9000, and it's finally ready to be released. You can find the github page here: https://github.com/slaclab/EK9000
The module requires Modbus R3-0 at least to function, and was built and tested on EPICS R3-14, but it should work well on later versions too.
As of right now the module only supports EL10xx, EL11xx, El20xx, EL21xx, EL30xx, EL31xx, EL40xx and EL41xx terminals. Support for motor terminals is currently being worked on, but won't arrive for at least a couple of months. If you would like support for another terminal type, I'd be happy to implement it.
There isn't a ton of documentation, but I've provided both sample IOC setup and small manual in the repository. If you find any bugs or have any issues, please let me know via email or through an issue on the github repository.
Feedback is always welcome!
Cheers,
Jeremy Lorelli
RE:EK9000 Device Support GAGET Alexis via Tech-talk
Prev: Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
Next: AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025
Prev: Re: Control System Studio (CSS) and array PV Kasemir, Kay via Tech-talk
Next: RE:EK9000 Device Support GAGET Alexis via Tech-talk
ANJ, 20 Sep 2019 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
