1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: AW: AW: Correct Settings for PIE816 Controller
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
To: "Peterson, Kevin M." <[email protected]>, "Rivers, Mark L." <[email protected]>, Torsten Bögershausen <[email protected]>
Date: Fri, 20 Sep 2019 07:32:45 +0000
Hi Kevin,
thanks for the help! The old driver is working fine for me, so I stay with it for now.
However if there will be a E-816 compatible EPICS PIGCS2 driver in future, I would change to it.
Michael
-----Ursprüngliche Nachricht-----
Von: Peterson, Kevin M. <[email protected]>
Gesendet: Donnerstag, 19. September 2019 17:08
An: Rivers, Mark L. <[email protected]>; Torsten Bögershausen <[email protected]>; Sintschuk, Michael <[email protected]>
Betreff: Re: AW: Correct Settings for PIE816 Controller
I created a github issue for this:
   https://github.com/epics-motor/motorPIGCS2/issues/3
I'm currently unable to email Steffen Rau for cybersecurity reasons that I don't understand.  He has told me in the past that he isn't able to access github due to proxy issues.  Given these communication difficulties, I would recommend using the old, non-PIGCS2 driver for now.
Kevin
On 9/19/19 6:46 AM, Mark Rivers wrote:
> Hi Michael,
> I think that a derived class for the E-816 would need to be written.  You could contact PI (Steffen Rau?) about that.  It looks like the motorPIGCS2 module should support both GCS and GCS2 devices.  Yours does not appear to be GCS2 because it does not list support for the CSV? command.
> Mark
Re: AW: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Torsten Bögershausen via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Re: AW: Correct Settings for PIE816 Controller Mark Rivers via Tech-talk
Prev: EK9000 Device Support Lorelli, Jeremy J via Tech-talk
Next: RE:EK9000 Device Support GAGET Alexis via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
Next: Re: AW: AW: Correct Settings for PIE816 Controller Peterson, Kevin M. via Tech-talk
ANJ, 20 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
