1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: RE:EK9000 Device Support
From: GAGET Alexis via Tech-talk <[email protected]>
To: "Lorelli, Jeremy J" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 20 Sep 2019 08:19:51 +0000
Hi Jeremy,
Congrats on your work
Using the EK9000 for our development we are very interested, I will look into your code maybe next week.
For the motion terminals, I have tested myself without success (the motor moved, but not in the way I wanted and I suppose nobody want that way...)
The Beckhoff support (the french one) directed me to the p53 of the EK9000 manual
"I would like to operate the drive terminals/drives on the EK9000. Is that possible?
No, use a CX with a suitable performance for this, e.g. CX9020 or higher."
So for now we are using the CX8190 and TwinCAT, I'm able to control variable I've mapped throught Modbus using their ModbusServer Functions (TF6250 | TC3 Modbus TCP)
Finally we are happy with that solution, we let the process (motor, interlock..etc) in the CX and use EPICS just for configuration and to monitor information.
Cheers
Alexis GAGET
CEA Saclay
IRFU/DIS/LDISC
De : Tech-talk [[email protected]] de la part de Lorelli, Jeremy J via Tech-talk [[email protected]]
Envoyé : jeudi 19 septembre 2019 20:20
À : [email protected]
Objet : EK9000 Device Support
Hello everyone,
As my summer internship project I've been working on device support for the Beckhoff EK9000, and it's finally ready to be released. You can find the github page here: https://github.com/slaclab/EK9000
The module requires Modbus R3-0 at least to function, and was built and tested on EPICS R3-14, but it should work well on later versions too.
As of right now the module only supports EL10xx, EL11xx, El20xx, EL21xx, EL30xx, EL31xx, EL40xx and EL41xx terminals. Support for motor terminals is currently being worked on, but won't arrive for at least a couple of months. If you would like support for another terminal type, I'd be happy to implement it.
There isn't a ton of documentation, but I've provided both sample IOC setup and small manual in the repository. If you find any bugs or have any issues, please let me know via email or through an issue on the github repository.
Feedback is always welcome!
Cheers,
Jeremy Lorelli
RE: EK9000 Device Support Dominic Oram - UKRI STFC via Tech-talk
EK9000 Device Support Lorelli, Jeremy J via Tech-talk
Prev: AW: AW: Correct Settings for PIE816 Controller Sintschuk, Michael via Tech-talk
Next: RE: EK9000 Device Support Dominic Oram - UKRI STFC via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: EK9000 Device Support Lorelli, Jeremy J via Tech-talk
ANJ, 20 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
