1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Problems with first ADSimdetector implementation
From: "Matteo C. via Tech-talk" <[email protected]>
Date: Mon, 13 Jan 2020 14:59:22 +0000
Good morning everybody,
I'm trying to get images from a little lab camera (of Thorlabs) using ADSimDetector for the first time, to get the feeling for areaDetector. What I did is:
-installed areaDetector with everything needed
-installed medm for .adl visualization
-installed ImageJ for image visualization
To try to get the images, I open first with medm the .adl of ADSimdetector and ImageJ, then open the corresponding IOC via the simDetectorApp. Lastly I activate the ADViewer plugin of ImageJ. To get the image, I then Eenable in the NDStdArrays plugin the Enable PV and here the image is supposed to appear, but instead I get this error from the IOC after pressing "Process Plugin":
NDPluginDriver::writeInt32 cannot do ProcessPlugin, no input array cached
2020/01/13 15:41:51.008 NDPluginDriver::writeInt32 ERROR, status=3, function=68, paramName=PROCESS_PLUGIN, value=1, connectedToArrayPort_=1
2020/01/13 15:41:51.008 13SIM1:image1:ProcessPlugin devAsynInt32::processCallbackOutput process write error
As far as I have understood there is no array where to put the data in, but I do not know how to fix it and I couldn't find a solution anywhere. Is it a problem of the camera detection or did I something wrong in the setup?
By the way, the camera is attached via an USB 3.0 if that can be helpful.
Thank you in advance,
Matteo.
Re: Problems with first ADSimdetector implementation Mark Rivers via Tech-talk
Prev: RE: subArray record [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Next: Re: Problems with first ADSimdetector implementation Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: subArray record [SEC=UNOFFICIAL] Johnson, Andrew N. via Tech-talk
ANJ, 13 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
