Hi Andrew, Michael,
Thank you for responses (now back from Xmas break, hence the delay).
camonitor -# 0 SR07BM01FPM01:FILL_PATTERN_ELEMENT_030_EXTRACT
shows 1 element which I want I want. However not sure if the Archive Appliance can be
configured to do the equivalent.
Appending the filter, .[30:30], also works, although we haven’t tried it with the Archive Appliance yet.
However the filter does work in EPICS Qt and in a database INP link with CA qualifier.
How did I miss that little nugget of EPICS know how?
Regards
Andrew
Hi Andrew,
On Dec 23, 2019, at 7:13 PM, STARRITT, Andrew via Tech-talk <tech-[email protected]> wrote:
Using base-3-15-6, running cainfo SR07BM01FPM01:FILL_PATTERN_ELEMENT_030_EXTRACT
yields
State: connected
Host: CR01GW17-CTL:5064
Access: read, no write
Native data type: DBF_DOUBLE
Request type: DBR_DOUBLE
Element count: 360
However, previously with an IOC using 3.14.8.4 this yielded a single valued PV.
The code change that Michael pointed out was a correction to the original subArray record code – the maximum number of elements of a CA channel should be fixed since many clients rely on that to allocate local storage for channel data,
but as you saw unfortunately the subArray code was returning NELM or NORD, both of which can be changed at runtime. cainfo reports the maximum array size, not the current size.
However from 3.15.1 onward you may be able to avoid having to use any subArray records at all since the IOC’s CA server supports channel filters, and specifically the array
filter. To fetch the item at index 30 you should be able to do this:
$ caget 'SR07BM01FPM01:FILL_PATTERN_ABS_WAVEFORM.[30:30]'
I believe cainfo with that channel name will also report a single element.
- Re: subArray record [SEC=UNOFFICIAL] Johnson, Andrew N. via Tech-talk
Re: EPICS release series after 7.0: 7.1 or 8.0? Ralph Lange via Tech-talk
Problems with first ADSimdetector implementation Matteo C. via Tech-talk
<2020>
RE: Carriage Return in asyn record IEOS/OEOS fields Mark Rivers via Tech-talk
<2020>
ANJ, 13 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
