Subject: Re: Killing caRepeater on Windows 10
From: "Hill, Jeff via Tech-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "Tech Talk ([email protected])" <[email protected]>
Date: Wed, 15 Jan 2020 22:56:03 +0000
FWIW:
In past releases of EPICS if windows is built debug, during development, then the caRepeater process is created with an associated console window, which makes it easier to stop. I have also, in the past, added an explicit caRepeater process kill commandl to my  build script, on windows.
Jeff
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Sent: Wednesday, January 15, 2020 3:36:17 PM
To: [email protected]
Subject: [EXTERNAL] Re: Killing caRepeater on Windows 10
On 1/14/20 12:19 AM, Michael Davidsaver wrote:
Has anyone ever spun caRepeater as a windows service?
https://docs.microsoft.com/en-us/windows/win32/services/svc-cpp
It looks like processes have to explicitly say that they should be run as a service for the standard Microsoft tool 'sc create' to work. However I have just managed to set up our standard caRepeater.exe to start automatically on my system using NSSM - the Non-Sucking Service Manager (great name!) which seems to be the recommended way to do this. I actually installed it with
C:\>choco install nssm
I love Chocolatey, it makes installing software on Windows so much easier than doing it by hand. Then created and started the new service using
C:\>nssm install "CA Repeater" C:\epics\bin\caRepeater.exe
C:\>nssm start "CA Repeater"
Now the repeater appears in the task manager as a background process, and should start automatically whenever the machine comes up. The nssm will also restart it if it ever dies for some reason.
Note that I copied a statically built caRepeater.exe into the above directory, I don't want to use the binary from one of my build directories because I'd have to stop and restart the service every time I rebuilt that copy of Base. You can use the caRepeater.exe from any version of Base, they all do exactly the same thing.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Killing caRepeater on Windows 10 Mark Rivers via Tech-talk
Re: Killing caRepeater on Windows 10 Michael Davidsaver via Tech-talk
Re: Killing caRepeater on Windows 10 Johnson, Andrew N. via Tech-talk
Prev: Re: Killing caRepeater on Windows 10 Johnson, Andrew N. via Tech-talk
Next: RE: EtherIP EPICS Support: Invalid Service 0x52 Guerra, Roy Ignacio via Tech-talk
Next: Re: Killing caRepeater on Windows 10 Žiga Oven via Tech-talk
