Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
Date: Fri, 17 Jan 2020 14:28:25 +0100
Am Fri, 17 Jan 2020 13:12:35 +0000
schrieb Mark Rivers <[email protected]>:
> > The built ioc complains about not finding the protocol file, but it
> > only looks in "."
>     - The line from your startup script that sets STREAM_PROTOCOL_PATH
epicsEnvSet("STREAM_PROTOCOL_PATH","/opt/rtapps/epics-3.15.3_long/aei/boostik/proto")
>     - The exact error message you are seeing when you say it does not
> find the protocol file?
Starting iocInit
## EPICS R3.15.3 $Date: Sun 2015-11-22 17:54:12 +0100$ ## EPICS Base built
Feb 17 2016
2020/01/17 14:25:32 Can't find readable file 'boostik.proto' in '.'
2020/01/17 14:25:32 while reading protocol 'setAmplifierDisable' for
[... various record initialization errors etc....]
> Are you seeing the following error message?  You should see this if the
> protocol path is really not set.
>           drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults
> to "."
No, I don't see that. That's why I wrote that it looks like the drvInit()
part is never called.
cu
  Gerrit
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
