Hi John, On Tue, Jan 28, 2020 at 12:24 PM John Dobbins <john.dobbins at cornell.edu> wrote:
I don't see those messages, but they look familiar: This seems like it might be related to changes that were made for TimeSeries around AD3.5 or AD3.6. I'm using the "iocGSECARS-4Channel" boot directory, which needs the more recent versions of AD. It may be that the other iocBoot directories are still using TimeSeries syntax that are based on AD2 (I think it might be "up to AD3.5"), which are subtly different than for AD 3.6 and higher. Does that seem it might be the culprit? If so, we should update all the iocBoot directories to be consistent with the latest version of AD3.
Oh, yes I do see that. The XSP3.xml NDAttributesFile has <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="INT"/> which should probably be <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="PARAM"/> We should fix that in master. --Matt Newville
ANJ, 28 Jan 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
