1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: XSPRESS3 hdf5 problems
From: John Dobbins via Tech-talk <tech-talk at aps.anl.gov>
To: Matt Newville <newville at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 28 Jan 2020 19:04:42 +0000
OK. I modified iocxspress-4Channel for six channels. I'll try starting with iocGSECARS-4Channel.
John
From: Matt Newville <newville at cars.uchicago.edu>
Sent: Tuesday, January 28, 2020 1:59 PM
To: John Dobbins <john.dobbins at cornell.edu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
Hi John,
On Tue, Jan 28, 2020 at 12:24 PM John Dobbins <john.dobbins at cornell.edu> wrote:
First, thanks to Matt Newville and Mark Rivers for your help in getting my XSPRESS3 IOC running. (I'll post later it it actually fixes our original problem.)
I have two questions related to the IOC:
On IOC start-up I get 48 messages (6 channels x 8 SCAs) of this type:
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA1:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA2:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
devAsynFloat64Array::initCommon, XSPRESS3:C1SCA3:TSArrayValue connectDevice failed asynManager:connectDevice port XSP3.C1SCA_TS not found
I don't see those messages, but they look familiar: This seems like it might be related to changes that were made for TimeSeries around AD3.5 or AD3.6.
I'm using the "iocGSECARS-4Channel" boot directory, which needs the more recent versions of AD.  It may be that the other iocBoot directories are still using TimeSeries syntax that are based on AD2 (I think it might be "up to AD3.5"), which are subtly different than for AD 3.6 and higher.   Does that seem it might be the culprit?  If so, we should update all the iocBoot directories to be consistent with the latest version of AD3.
Plus this message:
2020/01/28 12:57:33.650 asynNDArrayDriver:readNDAttributesFile: unknown attribute type = INT for attribute CHAN1DTCFLAGS
Oh, yes I do see that. The XSP3.xml NDAttributesFile has
    <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="INT"/>
which should probably be
    <Attribute addr="0" datatype="DOUBLE" description="Chan 1 DTC Flags" name="CHAN1DTCFLAGS" source="XSP3_CHAN_DTC_FLAGS" type="PARAM"/>
We should fix that in master.
--Matt Newville
XSPRESS3 hdf5 problems John Dobbins via Tech-talk
RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Prev: Re: XSPRESS3 hdf5 problems Matt Newville via Tech-talk
Next: Job Openings at ORNL for the STS Project Steven M. Hartman via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Next: CAEN SY127 via RS232 Jan Glorius via Tech-talk
ANJ, 28 Jan 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
