Subject: send/receive waveform over network.
From: Tomasz Brys via Tech-talk <[email protected]>
Date: Thu, 6 Feb 2020 15:42:38 +0000
Hi
I have a beginner question. I want to send via ethernet (TCP/UDP) a waveform from IOC to external device. The waveform consists of binary data and can be big so the Stream Device is not a solution. To simplify the problem, I tested it with longout and a local server listening on port 7777.
In my startup command I have:
drvAsynIPPortConfigure("det-stream", "localhost:7777")
Then I load my db, which is very simple:
record(longout, "p") {
    field(VAL, “1”)
    field(DTYP, "asynInt32")
    field(OUT,  "@asyn(det-stream)")
I started IOC, no errors. But how I can send the VAL over TCP?
“dbpf p 2” does not work, neither “dbpf p.PROC”
Do I have to write my own implementation of asynDriver?
Is it any differences between sending longout and waveform?
Regards
Tomasz
Prev: Re: ThorLabs motor driver Mark Rivers via Tech-talk
Next: Fwd: send/receive waveform over network. Mark Rivers via Tech-talk
Prev: Re: lock/unlock mutex problem Johnson, Andrew N. via Tech-talk
