Subject: Fwd: send/receive waveform over network.
Date: Thu, 6 Feb 2020 17:14:35 +0000
Forgot to CC tech-talk.
Sent from my iPhone
Begin forwarded message:
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: February 6, 2020 at 11:11:17 AM CST
To: Tomasz Brys <[email protected]<mailto:[email protected]>>
Subject: Re: send/receive waveform over network.
Hi Tomasz,
There is no limitation that prevents Stream Device from sending a large waveform. In fact I have done so with the Tabor waveform generator in the synApps "ip" module.
https://github.com/epics-modules/ip/blob/master/ipApp/Db/Tabor8024.proto
Sent from my iPhone
On Feb 6, 2020, at 11:02 AM, Tomasz Brys via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi
I have a beginner question. I want to send via ethernet (TCP/UDP) a waveform from IOC to external device. The waveform consists of binary data and can be big so the Stream Device is not a solution. To simplify the problem, I tested it with longout and a local server listening on port 7777.
In my startup command I have:
drvAsynIPPortConfigure("det-stream", "localhost:7777")
Then I load my db, which is very simple:
record(longout, "p") {
   field(VAL, "1")
   field(DTYP, "asynInt32")
   field(OUT,  "@asyn(det-stream)")
I started IOC, no errors. But how I can send the VAL over TCP?
"dbpf p 2" does not work, neither "dbpf p.PROC"
Do I have to write my own implementation of asynDriver?
Is it any differences between sending longout and waveform?
Regards
Tomasz
send/receive waveform over network. Tomasz Brys via Tech-talk
Prev: send/receive waveform over network. Tomasz Brys via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Next: Re: send/receive waveform over network. Mark Rivers via Tech-talk
