Hi Tomasz,
I am a little confused. You original post saint you wanted to send a big waveform from the IOC to the external device. But your second message said you want to receive a large waveform from the external device. Do you need to do both?
I think Stream Device can do both of these. But if you need to parse a message from the device in order to know how much data it will send that is beginning to sound complex enough that you might want to write a driver using asynPortDriver. You will use an underlying drvAsynIPPort driver to do the actual I/O.
There are examples of doing this in a number of drivers, for example the drvTetrAMM driver in the quadEM module, or the marCCD driver in areaDetector.
What type of device are you talking to?
Sent from my iPhone
> On Feb 6, 2020, at 11:40 AM, Tomasz Brys <Tomasz.Brys at ess.eu> wrote:
> Hi Mark,
> Thanks for you answer.
> Maybe I simplified too much my problem. The device is sending 16-bytes packets. I do not know in advance how many packets I will receive. I will know it after I analyze the first packet and proper response for it. Then I can get even MB of data. Is a stream device with interpose function still appropriate tool for that?
> Anyhow, How should I write my record from the previous email?
> Regards
> Tomasz
> On 2020-02-066 w:6, 18:15, "Tech-talk on behalf of Mark Rivers via Tech-talk" <tech-talk-bounces at aps.anl.gov on behalf of tech-talk at aps.anl.gov> wrote:
> Forgot to CC tech-talk.
> Sent from my iPhone
> Begin forwarded message:
> From: Mark Rivers <rivers at cars.uchicago.edu<mailto:rivers at cars.uchicago.edu>>
> Date: February 6, 2020 at 11:11:17 AM CST
> To: Tomasz Brys <Tomasz.Brys at ess.eu<mailto:Tomasz.Brys at ess.eu>>
> Subject: Re: send/receive waveform over network.
> Hi Tomasz,
> There is no limitation that prevents Stream Device from sending a large waveform. In fact I have done so with the Tabor waveform generator in the synApps "ip" module.
> https://github.com/epics-modules/ip/blob/master/ipApp/Db/Tabor8024.proto
> Mark
> Sent from my iPhone
> On Feb 6, 2020, at 11:02 AM, Tomasz Brys via Tech-talk <tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>> wrote:
> Hi
> I have a beginner question. I want to send via ethernet (TCP/UDP) a waveform from IOC to external device. The waveform consists of binary data and can be big so the Stream Device is not a solution. To simplify the problem, I tested it with longout and a local server listening on port 7777.
> In my startup command I have:
> drvAsynIPPortConfigure("det-stream", "localhost:7777")
> Then I load my db, which is very simple:
> record(longout, "p") {
> field(VAL, "1")
> field(DTYP, "asynInt32")
> field(OUT, "@asyn(det-stream)")
> I started IOC, no errors. But how I can send the VAL over TCP?
> "dbpf p 2" does not work, neither "dbpf p.PROC"
> Do I have to write my own implementation of asynDriver?
> Is it any differences between sending longout and waveform?
> Regards
> Tomasz
- Re: send/receive waveform over network. Tomasz Brys via Tech-talk
- send/receive waveform over network. Tomasz Brys via Tech-talk
- Fwd: send/receive waveform over network. Mark Rivers via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Re: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
<2020>
2025
<2020>
2025
