Hi Heinz
Thank you for the reply. I cleaned my /conf/context.xml file to match the default upon install and ran install_scripts/addMysqlConnPool.py. This inserts a "Resource" section as expect. I still get the same error. I have also confirmed that the MySQL daemon is running and listening on the correct port via netstat.
Regards
Peter
-----Original Message-----
From: Heinz Junkes [mailto:junkes at fhi-berlin.mpg.de]
Sent: Thursday, 20 February 2020 7:33 PM
To: Peter Linardakis <peter.linardakis at anu.edu.au>
Cc: tech-talk at aps.anl.gov
Subject: Re: EPICS Archiver appliance MySQL Persistence error
Dear Peter,
in my installation i have a file context.xml, it includes an url to the database:
<Resource name="jdbc/archappl"
auth="Container"
type="javax.sql.DataSource"
factory="org.apache.tomcat.jdbc.pool.DataSourceFactory"
username="archappl"
password="archappl"
testWhileIdle="true"
testOnBorrow="true"
testOnReturn="false"
validationQuery="SELECT 1"
validationInterval="30000"
timeBetweenEvictionRunsMillis="30000"
maxActive="10"
minIdle="2"
maxWait="10000"
initialSize="2"
removeAbandonedTimeout="60"
removeAbandoned="true"
logAbandoned="true"
minEvictableIdleTimeMillis="30000"
jmxEnabled="true"
driverClassName="com.mysql.jdbc.Driver"
url="jdbc:mysql://localhost:3306/archappl"
</Context>
To be honest, I don't know exactly where the file came from, but here I found a reference to it:
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 20. Feb 2020, at 06:14, Peter Linardakis via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hi all
> Attempted to build a single machine installation of an EPICS archiver appliance using the install_scripts/single_machine_install.sh script. Everything seemed to go OK with the install and the management URL displays correctly, except there are errors as below, which also show when you attempt to add a PV. The MySQL daemon is running and I have added a connection pool to conf/contect.xml as per https://slacmshankar.github.io/epicsarchiver_docs/installguide.html(although the error is identical without it).
> mysql-connector-java-8.0.19.jar is installed under /opt/archappl/tomcatinstances/apache-tomcat-9.0.31/lib/
> …/mgmt/logs/arch.log
> 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_SNAPSHOT_13-November-2019T15-45-42
> 1 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService -
> 28 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://nucserver4:17665/mgmt/bpl
> 29 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties from the webapp classpath /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
> 30 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/tomcatinstances/mgmt/webapps/mgmt/WEB-INF/classes/archappl.properties
> 11333 [Startup executor] INFO config.org.epics.archiverappliance.config.persistence.MySQLPersistence - Looking up datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
> 11334 [Startup executor] INFO config.org.epics.archiverappliance.config.persistence.MySQLPersistence - Found datasource called jdbc/archappl in the java:/comp/env namespace using JDNI
> 11335 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading PVTypeInfo from persistence
> 11347 [Startup executor] ERROR config.org.epics.archiverappliance.config.DefaultConfigService - Exception loading PVs from persistence java.io.IOException: java.sql.SQLException: Cannot create JDBC driver of class '' for connect URL 'null'
> at org.epics.archiverappliance.config.persistence.MySQLPersistence.getKeys(MySQLPersistence.java:145)
> at org.epics.archiverappliance.config.persistence.MySQLPersistence.getTypeInfoKeys(MySQLPersistence.java:51)
> Relevant lines form the startup file are:
> export JAVA_HOME=/usr/lib/jvm/jdk-13.0.2
> export TOMCAT_HOME=/opt/archappl/tomcatinstances/apache-tomcat-9.0.31
> export ARCHAPPL_DEPLOY_DIR=/opt/archappl/tomcatinstances
> export ARCHAPPL_APPLIANCES=/opt/archappl/tomcatinstances/appliances.xml
> export ARCHAPPL_MYIDENTITY="appliance0"
> Am I missing something basic?
> Regards
> Peter
> Dr Peter Linardakis
> Senior Accelerator R&D Engineer
> Nuclear Physics | Research School of Physics
> Australian National University
- EPICS Archiver appliance MySQL Persistence error Peter Linardakis via Tech-talk
- Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
Buffer full issue with ADAravis Katie Matusik via Tech-talk
Re: Buffer full issue with ADAravis Mark Rivers via Tech-talk
<2020>
2025
MEMD is stuck on windows-x64 杨栋亮 via Tech-talk
<2020>
2025
