1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
From: "CORNALL, Terry via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Apr 2020 02:20:05 +0000
For the record, I’ll put a nice answer here that I got from James Larson.
At the end of your exec statement
direct the output, >,  to /dev/null .  It won’t show up on the ioc .’
I tried that and it works a treat.
In the protocol file:
commsFail {
  #exec 'echo "comms fail on \$0"'; #Turn this off in production
  exec 'dbpf \$1:\$4 "Comms error"> /dev/null';  #/dev/null makes it silent
readCurrent{
…. Usual out and in stuff, then an exception handler for timeout
              @replytimeout{commsFail;} #comms is down
And in the database file:
#COMMSFAIL is the record to write to on a replytimeout
  field(INP, "@$(DEVICE).proto readCurrents($(P)$(R),ITIME_MON,OVR_STS,COMMSFAIL) $(PORT) 0")
Thanks James.
Prev: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Next: Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
ANJ, 31 Mar 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
