Hi Terry,
Another solution would be to do the following:
- On the asyn port set the option "disconnectOnReadTimeout". That way if the device does not respond it will disconnect the port.
- Load an asyn record that is connected to that asyn port.
- The asyn record CNCT field will change state when the port disconnects on read timeout.
- Use the CNCT field to control the COMSFAIL record.
IMHO this is a cleaner solution that does not involving launching a separate process.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of CORNALL, Terry via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, March 31, 2020 9:20 PM
To: tech-talk at aps.anl.gov
Subject: RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED]
For the record, I'll put a nice answer here that I got from James Larson.
'At the end of your exec statement
direct the output, >, to /dev/null . It won't show up on the ioc .'
I tried that and it works a treat.
In the protocol file:
commsFail {
#exec 'echo "comms fail on \$0"'; #Turn this off in production
exec 'dbpf \$1:\$4 "Comms error"> /dev/null'; #/dev/null makes it silent
readCurrent{
.... Usual out and in stuff, then an exception handler for timeout
@replytimeout{commsFail;} #comms is down
And in the database file:
#COMMSFAIL is the record to write to on a replytimeout
field(INP, "@$(DEVICE).proto readCurrents($(P)$(R),ITIME_MON,OVR_STS,COMMSFAIL) $(PORT) 0")
Thanks James.
- Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Johnson, Andrew N. via Tech-talk
- RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
Re: Newport DL325 Mark Rivers via Tech-talk
<2020>
<2020>
