On Mar 31, 2020, at 10:39 PM, Mark Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
IMHO this is a cleaner solution that does not involving launching a separate process.
In the protocol file:
commsFail {
#exec 'echo "comms fail on \$0"'; #Turn this off in production
exec 'dbpf \$1:\$4 "Comms error"> /dev/null'; #/dev/null makes it silent
Strictly speaking an “exec” command in a StreamDevice protocol file isn't actually launching a separate process, it’s just running “dbpf” as an iocShell command, which I assume happens in the context of whatever thread is executing the protocol.
You could run an external process if your exec string starts with the iocsh command “system” to launch it, but that isn’t what the above protocol snippet is doing.
</pedantic>
- Andrew
Complexity comes for free, simplicity you have to work for.
- RE: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] CORNALL, Terry via Tech-talk
- Re: getting streamDevice exception handler replyTimeout to write to a record [SEC=UNCLASSIFIED] Mark Rivers via Tech-talk
RE: NTNDArray array filter does not work on value Mark Rivers via Tech-talk
CS-STUDIO/BEAST Alarms to logstash? John Dobbins via Tech-talk
<2020>
<2020>
ANJ, 01 Apr 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
