Subject: Re: EtherNet/IP Simulator
From: "Jemian, Pete R. via Tech-talk" <[email protected]>
To: "Shen, Guobao" <[email protected]>, Tech-Talk <[email protected]>
Date: Fri, 1 May 2020 21:30:39 +0000
The protocols for the CS800 are very specific to the device  They broadcast identification packets by UDP to port 30303 and status packets to port 30304  (the whole LAN can get both of these), then receive commands directed to the CS800 by IP number via UDP on port 30305.  Not likely a method used by others.  Not similar to a conventional server with well-known server port.
  Pete R. Jemian, Ph.D.                <[email protected]>
  Beam line Controls and Data Acquisition
  Advanced Photon Source,   Argonne National Laboratory
  Argonne, IL  60439                   630 - 252 - 3189
     Education is the one thing for which people
        are willing to pay yet not receive.
Sent: Friday, May 1, 2020 3:36 PM
To: Jemian, Pete R.; Tech-Talk
Hi Pete,
Thanks for your prompt reply.
Yes, I am looking for a Python library which is able to communicate with my IOC.
I am wondering that there are libraries existed in our community already, therefore I don't have to start from scratch, and am able to save some development time.
Does your code for the CS800 controller support A-B EtherIP, therefore I can re-use it to communicate with my IOC?
Guobao
On 5/1/20, 3:28 PM, "Jemian, Pete R." <[email protected]> wrote:
    I recently simulated an Oxford CS800 CryoStream Controller (UDP communications) using Python and the socket package.  You might try that route.
    From: Tech-talk <[email protected]> on behalf of Shen, Guobao via Tech-talk <[email protected]>
    Sent: Friday, May 1, 2020 3:26 PM
    To: Tech-Talk
    Subject: EtherNet/IP Simulator
    Here at APS-U, we are looking for a mechanism to be able to simulator A-B PLC EtherNet/IP, therefore it would work with an EtherIP driver based IOC.
    Does anyone have any suggestion whether there is any existing module which we can use?
    Guobao
EtherNet/IP Simulator Shen, Guobao via Tech-talk
Re: EtherNet/IP Simulator Jemian, Pete R. via Tech-talk
Re: EtherNet/IP Simulator Shen, Guobao via Tech-talk
Prev: Re: Bug report: EPICS base 7.0.3.1, deadlock Michael Davidsaver via Tech-talk
Next: EPICS Qt 3.7.3 [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
Prev: Re: EtherNet/IP Simulator Shen, Guobao via Tech-talk
