On 5/1/20 3:08 AM, Jonas Nilsson via Tech-talk wrote:
> Hello,
> For lack of a better idea on where to report a bug in EPICS base, here it is;
In this case the pvAccessCPP module has both pvac::ClientProvider and the "ca" provider.
https://github.com/epics-base/pvAccessCPP
> Calling the destructor on more than one instance of a pvac::ClientProvider which has been constructed with a provider name of "ca" (channel access) causes (what appears to be) a deadlock. Using "pva" (pvAccess) does not appear to trigger this deadlock. I have attached a screenshot of where the deadlock appears to be located (from pausing the application when running it under a debugger).
Text is much preferred to screen shots.
Can you identify and provide a stack trace from the other thread(s) participating in this deadlock?
If not, please attach stack traces from all threads.
> The code that causes the triggers the deadlock can be found here: https://github.com/ess-dmsc/forward-epics-to-kafka/blob/a75fab2a7343906c147722825a258332fc2126e7/src/EpicsClient/EpicsClientMonitorImpl.h
I'm confused by the presence of both pvac::ClientProvider and the lower level epics::pvAccess::ChannelProvider.
The idea of the first is to avoid the complexities of the second.
> In this piece of code, the version of EPICS base used is 7.0.3.1. I believe I had a the same issue when testing with earlier versions of EPICS7 a few months back as well.
> /Jonas
- Bug report: EPICS base 7.0.3.1, deadlock Jonas Nilsson via Tech-talk
Re: EtherNet/IP Simulator Shen, Guobao via Tech-talk
Re: EtherNet/IP Simulator Jemian, Pete R. via Tech-talk
<2020>
2025
<2020>
2025
