Subject: Re: SoftIOC and Labview
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 27 May 2020 09:36:09 +0200
My 2cts - your mileage may vary:
The NI implementations of CA (client and server) were indeed getting better over time, but they started at a very low level of compatibility.
Their newest versions are pretty much working (at least for scalars), but - especially for their CA server - you are always in for some surprises, and your clients might need special configuration when talking to an NI Channel Access server.
I can just underline what Gabriel wrote: In my experience (which is obviously biased as I was working at BESSY for a long time), CALab is the most reliable, robust and stable CA client for LabVIEW.
(Doesn't just look better - it works better, too!)
Cheers,
~Ralph
On Wed, 27 May 2020 at 08:27, Gabriel Fedel via Tech-talk <[email protected]> wrote:
I had the same problem with older versions of Labview. As soon I know
the waveform implementation on Labview is wrong, so you shouldn't trust
on it.
An alternative is CALab
(https://www.helmholtz-berlin.de/zentrum/locations/it/software/exsteuer/calab/index_en.html),
I've tried once and it looks much better than NI solution.
RE: SoftIOC and Labview Kathryn Baker - UKRI STFC via Tech-talk
SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Re: SoftIOC and Labview Paul Sichta via Tech-talk
Re: SoftIOC and Labview Mostafa, Jalal (IPE) via Tech-talk
Re: SoftIOC and Labview Gabriel Fedel via Tech-talk
Prev: Re: Unpredictable behaviour with PyEpics Simon Rose via Tech-talk
Next: RE: SoftIOC and Labview Kathryn Baker - UKRI STFC via Tech-talk
Prev: Re: SoftIOC and Labview Gabriel Fedel via Tech-talk
