Subject: Re: Strange problem with areaDetector driver
To: Jörn Dreyer <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 29 May 2020 11:37:26 +0000
> For the IOC I set EPICS_CA_MAX_ARRAY_BYTES=800000000.
That is nearly 1 GB. My understanding is that you should not use such a large value, because CA will actually allocate arrays of that size any time the actual array size is greater than 16 KB.  It's better to set EPICS_CA_MAX_ARRAY_BYTES to be just a bit larger than the largest array you will actually use.
From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
Sent: Friday, May 29, 2020 2:00 AM
To: [email protected]
My CS-Studio is based on the 4.5.1 release. I build it myself to have a site specific version.
As I mentioned, I have successfully used it with aravisGigE Cameras, mainly from Basler.
I have set a similar Value in CS-Studio But I can't check it at the moment. Yesterday I tried to build Phoebus and this somehow screwed up my CSS instalation.
Jörn
Am Donnerstag, 28. Mai 2020, 15:54:44 CEST schrieb Hu, Yong via Tech-talk:
> That is odd. We are using CS-Studio heavily for areaDetector at NSLS-II and
> have not seen such problems.
> Which version of CS-Studio are you using? What is the settings of
> EPICS_CA_MAX_ARRAY_BYTES both on your camera IOC side and on your CS-Studio
> side?
> We are using rules with PVs in IntensityGraph to automatically set Data
> width / height instead of manually configuring those parameters. I can send
> our .opi to you if you want (after your problems are fixed).
> Best luck!
> Yong Hu
> NSLS-II Controls Group
> On 5/28/20, 4:24 AM, "Tech-talk on behalf of Jörn Dreyer via Tech-talk"
> <[email protected] on behalf of [email protected]> wrote:
>     Hello
>     After some debugging, it turns out that the reason for the problem is
>     CS-Studio.
>     I have set up an opi Scene with an IntesityGraph for the Image. If I set
> the
 Data width and Data high to zero, the scene chanes from "No data" to
> "disconnected". If I set Data width to 4565 and Data height to 3520, the
> scene can not be loaded and results in java.lang.IllegalArgumentException.
> No further information is available. The scene can then even not get loaded
> into the OPI Editor and needs to be modified in a text editor.
>     For other cameras I was able to set the data height and data width
> parameters
 of the IntensityGraph to 2048 x 2048. Is there a size limit
> for this Widget? I did not find any hints obn that in the documentation.
>     Regards,
>     Jörn Drteyer
>     Am Donnerstag, 28. Mai 2020, 09:29:58 CEST schrieb Jörn Dreyer via
> Tech-talk:
>     > Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via
>     > Tech-talk:
>     > > > Closed the OPI screen that shows the image. Now the number of
>     > > > threads is
>     > > > constant. System load is at normal level.
>     > > When you saw the threads and high system load did you use top -H to
>     > > see
>     > > whether the threads with high CPU load were CSS threads or IOC
>     > > threads? I
>     > > suspect they are CSS threads.
>     > No they are all started from the IOC. After 300 threads spawned I
>     > decided to
 stop the IOC. I used
>     > ps -eLF | grep st.cmd | wc
>     > > > Will need some time to gat that going. Java on my system seems to
>     > > > have
>     > > > problem with the code.
>     > > ImageJ on both Linux and Windows comes with its own version of Java
>     > > in the
>     > > ImageJ/jre directory, so it should be completely independent of
>     > > your
>     > > system
>     > > version of Java.  Get the latest version of the ImageJ zip file and
>     > > install
>     > > it in your own directory so you don't need to worry about system
>     > > permissions, etc.
>     > I got it working, but there seems to be a problem that only half of
>     > the
>     > image is intrerpreted correctly. The ArrayType is UInt16 instead of
>     > UInt8.
>     > Will need to find out teh reason for that.
>     > Regards,
>     > Jörn
>     > > Mark
>     > > -----Original Message-----
>     > > From: Tech-talk <[email protected]> On Behalf Of Jörn
>     > > Dreyer
>     > > via Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM
>     > > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
>     > > > Hi Jörn,
>     > > > > I ran into a severe problem in the image readout handler.
>     > > > > When calling doCallbackGenericPointer() the IOC creates every
>     > > > > time a
>     > > > > couple of  new threads and consumes lot of CPU power ( 300% on
>     > > > > a
>     > > > > quad core).
>     > > > First a few questions:
>     > > > Is this Linux or Windows?
>     > > Linux
>     > > > What frame rate are you using?
>     > > 0.5 Hz
>     > > > What plugins are running?
>     > > Only NDStdArray.
>     > > > Is the CS-Studio GUI on the same machine as the IOC or a
>     > > > different
>     > > > machine?
>     > > On the same machine
>     > > > The first thing to establish is whether the problem is the
>     > > > areaDetector IOC or the CS-Studio client.  I suggest you do the
>     > > > following:
>     > > > -  Disable all plugins except NDPluginStdArrays for testing.
>     > > Done,
>     > > > - Exit CS-Studio so there is no display client running.  What is
>     > > > the
>     > > > CPU load under those conditions?
>     > > threads is
>     > > > - Try the ImageJ viewer instead of CS-Studio for testing.  Does
>     > > > that
>     > > > also have the problem?
>     > > have
>     > > Regards,
>     > > Jörn
>     > > > Mark
>     > > > ________________________________
>     > > > Dreyer via Tech-talk <[email protected]> Sent: Wednesday, May
>     > > > 27,
>     > > > 2020 7:03 AM
>     > > > Subject: Strange problem with areaDetector driver
>     > > > Hello,
>     > > > currently I have a very strange problem in a code I'm developing
>     > > > to
>     > > > read out cameras from ZWO. I ran into a severe problem in the
>     > > > image
>     > > > readout handler. When calling doCallbackGenericPointer() the IOC
>     > > > creates
>     > > > every time a couple of new threads and consumes lot of CPU power (
>     > > > 300%
>     > > > on a quad core). So after a very short time the system becomes
>     > > > unresponsive and has to be switched off. The image is 3520*4656
>     > > > bytes in
>     > > > size and is in monochrome mode, so UInt8 as data type.
Re: Strange problem with areaDetector driver Michael Davidsaver via Tech-talk
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
Prev: Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Next: AW: pco Camera USB and IEEE interface Sintschuk, Michael via Tech-talk
Next: Re: Strange problem with areaDetector driver Michael Davidsaver via Tech-talk
