Subject: Re: Strange problem with areaDetector driver
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Jörn Dreyer <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 29 May 2020 08:55:32 -0700
On 5/29/20 4:37 AM, Mark Rivers via Tech-talk wrote:
>> For the IOC I set EPICS_CA_MAX_ARRAY_BYTES=800000000.
> That is nearly 1 GB. My understanding is that you should not use such a large value, because CA will actually allocate arrays of that size any time the actual array size is greater than 16 KB.  It's better to set EPICS_CA_MAX_ARRAY_BYTES to be just a bit larger than the largest array you will actually use.
On the IOC side, in the Base 3.16 and 7.0 series EPICS_CA_MAX_ARRAY_BYTES is
ignored by default, and buffers are realloc()'d as needed beyond the 16KB minimum.
(the old behavior can still be restored by setting EPICS_CA_AUTO_ARRAY_BYTES=NO)
I believe that CAJ has similar logic, though it has been awhile since I looked.
In any event, it's probably not a good idea to set EPICS_CA_MAX_ARRAY_BYTES
so large.  It's either unnecessary (>=3.16) or wastes a lot of memory (<=3.15).
> Mark
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Jörn Dreyer via Tech-talk <[email protected]>
> Sent: Friday, May 29, 2020 2:00 AM
> To: [email protected]
> My CS-Studio is based on the 4.5.1 release. I build it myself to have a site specific version.
> As I mentioned, I have successfully used it with aravisGigE Cameras, mainly from Basler.
> I have set a similar Value in CS-Studio But I can't check it at the moment. Yesterday I tried to build Phoebus and this somehow screwed up my CSS instalation.
> Jörn
> Am Donnerstag, 28. Mai 2020, 15:54:44 CEST schrieb Hu, Yong via Tech-talk:
>> That is odd. We are using CS-Studio heavily for areaDetector at NSLS-II and
>> have not seen such problems.
>> Which version of CS-Studio are you using? What is the settings of
>> EPICS_CA_MAX_ARRAY_BYTES both on your camera IOC side and on your CS-Studio
>> side?
>> We are using rules with PVs in IntensityGraph to automatically set Data
>> width / height instead of manually configuring those parameters. I can send
>> our .opi to you if you want (after your problems are fixed).
>> Best luck!
>> Yong Hu
>> NSLS-II Controls Group
>> On 5/28/20, 4:24 AM, "Tech-talk on behalf of Jörn Dreyer via Tech-talk"
>> <[email protected] on behalf of [email protected]> wrote:
>>     Hello
>>     After some debugging, it turns out that the reason for the problem is
>>     CS-Studio.
>>     I have set up an opi Scene with an IntesityGraph for the Image. If I set
>> the
>  Data width and Data high to zero, the scene chanes from "No data" to
>> "disconnected". If I set Data width to 4565 and Data height to 3520, the
>> scene can not be loaded and results in java.lang.IllegalArgumentException.
>> No further information is available. The scene can then even not get loaded
>> into the OPI Editor and needs to be modified in a text editor.
>>     For other cameras I was able to set the data height and data width
>> parameters
>  of the IntensityGraph to 2048 x 2048. Is there a size limit
>> for this Widget? I did not find any hints obn that in the documentation.
>>     Regards,
>>     Jörn Drteyer
>>     Am Donnerstag, 28. Mai 2020, 09:29:58 CEST schrieb Jörn Dreyer via
>> Tech-talk:
>>     > Am Mittwoch, 27. Mai 2020, 16:10:26 CEST schrieb Mark Rivers via
>>     > Tech-talk:
>>     > > > Closed the OPI screen that shows the image. Now the number of
>>     > > > threads is
>>     > > > constant. System load is at normal level.
>>     > > When you saw the threads and high system load did you use top -H to
>>     > > see
>>     > > whether the threads with high CPU load were CSS threads or IOC
>>     > > threads? I
>>     > > suspect they are CSS threads.
>>     > No they are all started from the IOC. After 300 threads spawned I
>>     > decided to
>  stop the IOC. I used
>>     > ps -eLF | grep st.cmd | wc
>>     > > > Will need some time to gat that going. Java on my system seems to
>>     > > > have
>>     > > > problem with the code.
>>     > > ImageJ on both Linux and Windows comes with its own version of Java
>>     > > in the
>>     > > ImageJ/jre directory, so it should be completely independent of
>>     > > your
>>     > > system
>>     > > version of Java.  Get the latest version of the ImageJ zip file and
>>     > > install
>>     > > it in your own directory so you don't need to worry about system
>>     > > permissions, etc.
>>     > I got it working, but there seems to be a problem that only half of
>>     > the
>>     > image is intrerpreted correctly. The ArrayType is UInt16 instead of
>>     > UInt8.
>>     > Will need to find out teh reason for that.
>>     > Regards,
>>     > Jörn
>>     > > Mark
>>     > > -----Original Message-----
>>     > > From: Tech-talk <[email protected]> On Behalf Of Jörn
>>     > > Dreyer
>>     > > via Tech-talk Sent: Wednesday, May 27, 2020 8:56 AM
>>     > > Am Mittwoch, 27. Mai 2020, 14:46:09 CEST schrieb Mark Rivers:
>>     > > > Hi Jörn,
>>     > > > > I ran into a severe problem in the image readout handler.
>>     > > > > When calling doCallbackGenericPointer() the IOC creates every
>>     > > > > time a
>>     > > > > couple of  new threads and consumes lot of CPU power ( 300% on
>>     > > > > a
>>     > > > > quad core).
>>     > > > First a few questions:
>>     > > > Is this Linux or Windows?
>>     > > Linux
>>     > > > What frame rate are you using?
>>     > > 0.5 Hz
>>     > > > What plugins are running?
>>     > > Only NDStdArray.
>>     > > > Is the CS-Studio GUI on the same machine as the IOC or a
>>     > > > different
>>     > > > machine?
>>     > > On the same machine
>>     > > > The first thing to establish is whether the problem is the
>>     > > > areaDetector IOC or the CS-Studio client.  I suggest you do the
>>     > > > following:
>>     > > > -  Disable all plugins except NDPluginStdArrays for testing.
>>     > > Done,
>>     > > > - Exit CS-Studio so there is no display client running.  What is
>>     > > > the
>>     > > > CPU load under those conditions?
>>     > > threads is
>>     > > > - Try the ImageJ viewer instead of CS-Studio for testing.  Does
>>     > > > that
>>     > > > also have the problem?
>>     > > have
>>     > > Regards,
>>     > > Jörn
>>     > > > Mark
>>     > > > Dreyer via Tech-talk <[email protected]> Sent: Wednesday, May
>>     > > > 27,
>>     > > > 2020 7:03 AM
>>     > > > Subject: Strange problem with areaDetector driver
>>     > > > Hello,
>>     > > > currently I have a very strange problem in a code I'm developing
>>     > > > to
>>     > > > read out cameras from ZWO. I ran into a severe problem in the
>>     > > > image
>>     > > > readout handler. When calling doCallbackGenericPointer() the IOC
>>     > > > creates
>>     > > > every time a couple of new threads and consumes lot of CPU power (
>>     > > > 300%
>>     > > > on a quad core). So after a very short time the system becomes
>>     > > > unresponsive and has to be switched off. The image is 3520*4656
>>     > > > bytes in
>>     > > > size and is in monochrome mode, so UInt8 as data type.
Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Jörn Dreyer via Tech-talk
Re: Strange problem with areaDetector driver Hu, Yong via Tech-talk
Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Prev: Re: pco Camera USB and IEEE interface Bradnick, Ben (Tessella, RAL, TEC) via Tech-talk
Next: Re: pco Camera USB and IEEE interface Mark Rivers via Tech-talk
Prev: Re: Strange problem with areaDetector driver Mark Rivers via Tech-talk
Next: display builder web runtime 吴煊 via Tech-talk
