Subject: Re: Long String support in phoebus
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 14 Jul 2020 11:54:53 +0200
Just for the record:
Channel Access has no concept of "records" or "fields". (These are concepts of the EPICS Database.)
In the context of CA, a PV is basically anything that a server will resolve as something that is accessible.
The convenience fallback of using a record's value field if no field is specified is implemented in the EPICS Database - CA is unaware that this is happening.
Consequently, the "<pv_name>" in this thread should rather be "<record_name>", as the related statements apply when connecting to an EPICS IOC Database.
Cheers,
~Ralph
Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Mark Rivers via Tech-talk
Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Re: Long String support in phoebus Johnson, Andrew N. via Tech-talk
Prev: Re: Long String support in phoebus Nonn, Patrick via Tech-talk
Next: Re: Asyn/StreamDevice for HP3458A through Agilent E5810 LAN/GPIB Gateway Hu, Yong via Tech-talk
Next: Stream device - general concept how to use Christian Pauly via Tech-talk
