Subject: Stream device - general concept how to use
From: Christian Pauly via Tech-talk <[email protected]>
To: [email protected]
Date: Thu, 16 Jul 2020 10:02:35 +0200
Dear experts
I am struggling right now with programming a control interface for a device using the streamdevice module. The device has several status variables (like eg "temperature"), and several control variables (like eg "pump speed").
My approach is, to have for each control variable two records:
record getPumpSpeed  (type analog input, ai)
record setPumpSpeed  (type analog output, ao)
These are connected to two different protocol functions to set - or to read back the value.
"caput setPumpSpeed xxx" works fine : The protocol gets executed, the pump speed is set.
but "caget getPumpSpeed" does not execute the protocol, instead it just returns the record value. I could do a "caput getPumpSpeed xxx" first (with some arbitrary number xxx, to execute the record), then the protocol is executed, and a subsequent "caget getPumpSpeed" gives me the latest value... But that is not really what i want. (Naively) i am looking for a "realtime" readback everytime i do a caget.
But from the documentation i see, that this is the intended behaviour.
I could set the SCAN field of the caget record to have regular polls of the pump speed. But if i now imagine to have hundred such variables, i would get quite some traffic, and the return values are still not really "real time".
So: What is the general concept how to control such a device ? (This must be a "standard case").
Use SCAN for each status variable ?
Or combine the set- and get-record to a single record "PumpSpeed" ?
And just assume, that the latest set value (which is then returned upon caget) is still the actual real value ?
Or am i lacking some understanding of streamdevice ?
Any help and advice greatly appreciated !
Christian
Re: Stream device - general concept how to use Mark Rivers via Tech-talk
Prev: Re: SRQ over VXI Noboru Yamamoto via Tech-talk
Next: Pure Python IOC (CAProcess issue) Simon Reiter via Tech-talk
Prev: Re: Long String support in phoebus Ralph Lange via Tech-talk
Next: Re: Stream device - general concept how to use Mark Rivers via Tech-talk
