Hello all, -- My co-worker has setup a TCP virtual interface in LabVIEW, that allows me to send commands as strings of text, and get replies with data. Testing in a Linux shell using netcat (nc on CentOS 7) works well. echo "foobar\r" | nc -h hex.dump labview-host.foo.bar However, when I attempt to use Stream / Asyn, I get only timeouts. Stream and asynOctetWriteRead() both timeout. One would usually suspect that the line terminators are incorrect. To test line terminators, I turned on the netcat hexdump and can see both a CR and LF (0xD 0xA) being sent in a working netcat test. I put both in my stream protocol file and hard coded when using asynOctetWriteRead. I'm beginning to wonder if there's a protocol difference between what netcat does and what a generic TCP connection does. Does anyone have advice on what else I can try to tease out the problem ? Cheers and TIA ! dpc Daniel Cuneo ALS Accelerator Controls BLD 46-172G desk: 510-486-5439 cell: 415-871-1909
ANJ, 21 Jul 2020 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
