1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: RE: [EXTERNAL] caget for base7 records
From: Sandeep Kumar Malu - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
To: "Hartman, Steven" <hartmansm at ornl.gov>, "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 21 Jul 2020 07:02:35 +0000
Hi Andrew & Steven
I thought the same to use pvapy & pcaspy to do the mapping. Thank you for the suggestion.
As of now, we are running V4 IOC as a trial & will use pvAccess on the client side too.
Many Thanks
Sandeep
-----Original Message-----
Sent: Tuesday, July 21, 2020 3:55 AM
To: Malu, Sandeep Kumar (-,RAL,CLF) <sandeep-kumar.malu at stfc.ac.uk>
Subject: Re: [EXTERNAL] caget for base7 records
> On Jul 20, 2020, at 1:41 PM, Sandeep Kumar Malu - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov> wrote:
> I wish to use channel access method on client side to fetch  V4 Scalar PVRecords.
Is there a reason you cannot use pvAccess on the client side (e.g. pvget instead of caget)? If so, is there a reason you chose to use pvDatabase on the server side?
Steven Hartman
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: caget for base7 records Johnson, Andrew N. via Tech-talk
RE: caget for base7 records Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Prev: Re: TCP to LabVIEW TCP VI using Stream Device. Mark Rivers via Tech-talk
Next: Re: RE: SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Prev: Re: [EXTERNAL] caget for base7 records Hartman, Steven via Tech-talk
Next: TCP to LabVIEW TCP VI using Stream Device. Daniel Cuneo via Tech-talk
ANJ, 21 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
