1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: RE: SteamDevice 2.8.x build on Windows issue
From: Freddie Akeroyd - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
To: 吴煊 <wux at ihep.ac.cn>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 21 Jul 2020 12:17:15 +0000
The issue looks to be that it is not able to read the STREAM_PROTOCOL_PATH environment variable when using 2.8.13
Could you see if applying the change at https://github.com/paulscherrerinstitute/StreamDevice/commit/bd9ee1c660d91e4be31c6dd4ac5641eec10886da
and rebuilding stream device makes any difference?
Freddie
Sent: 21 July 2020 08:57
To: Akeroyd, Freddie (STFC,RAL,ISIS) <freddie.akeroyd at stfc.ac.uk>
Cc: mark rivers <rivers at cars.uchicago.edu>; tech-talk at aps.anl.gov
Subject: Re: RE: SteamDevice 2.8.x build on Windows issue
There is something wrong with what I said in my previous email. It's ture that steam 2.8.13 can be built successfully with Visual Studio 2017 and Visual Studio 2019. However, it will be aborted when the application start(when execute iocInit actually), but it can be run correctly with Stream 2.7.14. You can check the info in attachment.
I also try to compile stream with 3.14.12.8:
MSVC:2017 community
EPICS_HOST_ARCH=windows-x64
Stream 2.8.13 can be built, but the application can't be run properly. The result is the same as Stream2.8.13.PNG
EPICS_HOST_ARCH=windows-x64-mingw
Stream 2.8.13 build failed. The error info is :../ChecksumConverter.cc:777:51: error: expected ')' before 'SCNx8' Regards,
Xuan
-----原始邮件-----
发件人:"Freddie Akeroyd - UKRI STFC" <freddie.akeroyd at stfc.ac.uk>
发送时间:2020-07-20 20:31:01 (星期一)
收件人: "Mark Rivers" <rivers at cars.uchicago.edu>, "'吴煊'" <wux at ihep.ac.cn>
抄送: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
I wasn’t able to check your exact combination, but I ran a few visual studio combinations from 2013 to 2019 through Appveyor and they all seemed OK
https://ci.appveyor.com/project/FreddieAkeroyd/streamdevice/builds/34184691
Maybe it is picking up an incorrect include or definition from somewhere - if you check the C pre-processor output for the file compilation that will show what headers are being loaded from where and might help locate the issue
Freddie
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Mark Rivers via Tech-talk
Sent: 19 July 2020 20:51
To: '
吴煊' <wux at ihep.ac.cn>
Cc: tech-talk at aps.anl.gov
Subject: RE: SteamDevice 2.8.x build on Windows issue
I just built stream 2.8.14 successfully with both Visual Studio 2015 and Visual Studio 2017.  I don’t have 2019 installed so I could not test that, but I would be surprised if it failed.
My environment:
OS:Windows 10 x64
base7.0.4
asyn4-40
MSVC2015, 2017 Community
GNU make:4.2.1
Perl64:5.24.3
SCNx8 is defined in inttypes.h for Visual Studio.  This is where it is found in all of the inttypes.h files in C:\Program Files (x86)\Windows Kits.
[2020-07-19 14:46.55]  /cygdrive/c/Program Files (x86)/Windows Kits
[rivers.Camaro] find . -name inttypes.h -exec grep -H SCNx8 {} \;
./10/Include/10.0.10150.0/ucrt/inttypes.h:#define SCNx8        "hhx"
./10/Include/10.0.10150.0/ucrt/inttypes.h:#define SCNxLEAST8   SCNx8
./10/Include/10.0.10150.0/ucrt/inttypes.h:#define SCNxFAST8    SCNx8
./10/Include/10.0.10240.0/ucrt/inttypes.h:#define SCNx8        "hhx"
./10/Include/10.0.10240.0/ucrt/inttypes.h:#define SCNxLEAST8   SCNx8
./10/Include/10.0.10240.0/ucrt/inttypes.h:#define SCNxFAST8    SCNx8
./10/Include/10.0.16299.0/ucrt/inttypes.h:#define SCNx8        "hhx"
./10/Include/10.0.16299.0/ucrt/inttypes.h:#define SCNxLEAST8   SCNx8
./10/Include/10.0.16299.0/ucrt/inttypes.h:#define SCNxFAST8    SCNx8
./10/Include/10.0.17763.0/ucrt/inttypes.h:#define SCNx8        "hhx"
./10/Include/10.0.17763.0/ucrt/inttypes.h:#define SCNxLEAST8   SCNx8
./10/Include/10.0.17763.0/ucrt/inttypes.h:#define SCNxFAST8    SCNx8
I also found that git needed to be installed on Windows to build 2.8.14.  For other modules with base 7.0.4 it was sufficient to make “fake” git.bat that just contained:
@echo GSECARS-Build
However, stream actually checks the syntax of the returned string, and that trick fails.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of ?? via Tech-talk
Sent: Sunday, July 19, 2020 8:19 AM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: SteamDevice 2.8.x build on Windows issue
Hi all,
  I find that the SteamDevice(from 2.8 to 2.8.14) can not be built on Win7 x64. The error info is :../ChecksumConverter.cc:777:51: error: expected ')' before 'SCNx8'. However the version of 2.7.14 can be built successfully. I've checked the file ChecksumConverter.cc, there is some difference between them like following:
2.8.x:   if (sscanf(input(cursor+2*i), "%2" SCNx8, &inchar) != 1)
2.7.14:  if (sscanf(input(cursor+2*i), "%2X", &inchar) != 1)
The software environment I'm using:
OS:Win7 x64
base3.15.8
asyn4-38
MSVC2019 community
GNU make:4.2.1
Strawberry:5.30.1
PSSteamDevice 2.8.14 is dependency with git, the other versions are not
Cheers,
Xuan
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
RE: SteamDevice 2.8.x build on Windows issue Freddie Akeroyd - UKRI STFC via Tech-talk
Re: RE: SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
Prev: Assign actions to Combobox items in Phoebus Peter Leban via Tech-talk
Next: Re: [EXTERNAL] Assign actions to Combobox items in Phoebus Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: RE: SteamDevice 2.8.x build on Windows issue 吴煊 via Tech-talk
Next: RE: RE: SteamDevice 2.8.x build on Windows issue Mark Rivers via Tech-talk
ANJ, 21 Jul 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
