Thanks Yong, I took a look at the https://epics.anl.gov/tech-talk/2017/msg00705.php thread and checked the various hints, unfortunately I do think what is suggested in those threads is the problem (?). My PV shows "Appliance assigned" in the archiver browser followed by a bunch of N/A despite the changing value of my PV. It's not seen/sampled/monitored at all by the archiver. the permissions in the s/l/m write directories seem ok ie ls -lrt -h /home/arch/sts/ total 4.0K drwxr-xr-x 2 tomcat tomcat 4.0K Jul 20 16:14 ArchiverStore looking at the logs under ls -lrt -h /opt/archappl/retrieval/logs/ I do not see suspicious entries, I still think something is wrong in my setup I checked the ports, I think these are ok sudo firewall-cmd --direct --get-rules ipv4 filter INPUT 0 -s 10.0.0.0/8 -p udp --sport 5064 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --dport 5065 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 5075 -j ACCEPT finally, I attach my arch.log and my retrieval_catalina.err files (tails pasted) any input will be appreciated. Thanks! tail /opt/archappl/retrieval/logs/arch.log 17 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl.properties 19 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by : 30128 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt limit: -1 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt period: 3000 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn timeout: 5000 30462 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config addresses: 10.0.0.78:16670 30462 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config is redo: false 30463 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client config properties: {hazelcast.logging.type=log4j} 31945 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL [amorreal@localhost arch]$ tail /opt/archappl/retrieval/logs/retrieval_catalina.err Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet lambda$init$0 INFO: pool-1-thread-1 Jul 24, 2020 5:11:26 PM org.epics.archiverappliance.retrieval.pva.PvaDataRetrievalServlet init INFO: 2020-07-24T17:11:26.878-06:00[America/Denver]pvaDataRetrievalService is operational. Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.HostConfig deployDirectory INFO: Deployment of web application directory [/opt/archappl-2020Jul20-1614-27MDT/retrieval/webapps/retrieval] has finished in [6,405] ms Jul 24, 2020 5:11:26 PM org.apache.coyote.AbstractProtocol start INFO: Starting ProtocolHandler ["http-nio-17668"] Jul 24, 2020 5:11:26 PM org.apache.catalina.startup.Catalina start INFO: Server startup in [6,501] milliseconds Il giorno gio 23 lug 2020 alle ore 20:52 Hu, Yong <yhu at bnl.gov> ha scritto:
-- Astrid Morreale
Staff Scientist Subatomic Physics Group. Los Alamos National Laboratory. astrid at lanl.gov 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T 1 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - 6 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl 8 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties 9 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl.properties 11 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by : 30133 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL 30349 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt limit: -1 30349 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt period: 3000 30349 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn timeout: 5000 30362 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config addresses: 10.0.0.78:16670 30362 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config is redo: false 30362 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client config properties: {hazelcast.logging.type=log4j} 31393 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T 1 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - 13 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl 16 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties 18 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl.properties 20 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by : 30186 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL 30384 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt limit: -1 30384 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt period: 3000 30384 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn timeout: 5000 30393 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config addresses: 10.0.0.78:16670 30393 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config is redo: false 30393 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client config properties: {hazelcast.logging.type=log4j} 31593 [http-nio-17668-exec-2] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T 2 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - 14 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl 26 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties 26 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl.properties 28 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by : 30371 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL 30575 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt limit: -1 30575 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt period: 3000 30575 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn timeout: 5000 30584 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config addresses: 10.0.0.78:16670 30584 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config is redo: false 30584 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client config properties: {hazelcast.logging.type=log4j} 31728 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T 1 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - 13 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl 16 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties using the environment/JVM property from /opt/archappl/archappl.properties 17 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl.properties 19 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\:\-] and the key names are terminated by : 30128 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for RETRIEVAL 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt limit: -1 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn attempt period: 3000 30447 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config conn timeout: 5000 30462 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config addresses: 10.0.0.78:16670 30462 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client network config is redo: false 30463 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - client config properties: {hazelcast.logging.type=log4j} 31945 [http-nio-17668-exec-1] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp RETRIEVAL Attachment:
ANJ, 27 Jul 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
