Thanks a lot Abdalla, I added those ports you suggested and now I am seeing more output in the logs. 1. the catalina error first warns me(then goes to error) about a memory leak...and threadlocal key? something should have been cleaned up but I am not sure where these keys are. 2. The arch log file warne me about an access denied "1818 [Startup executor] ERROR
org.epics.archiverappliance.config.DefaultConfigService - Exception
parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_HOUR&consolidateOnShutdown=true java.nio.file.AccessDeniedException: /home/arch/sts" yet this directory should be readable ls -lrt -h /home/arch/sts lrwxrwxrwx 1 tomcat tomcat 43 Jul 20 16:07 /home/arch/sts -> '/run/media/amorreal/Linux ext/archiver/shm/" Could it be because the simlink points to an external drive? the two log files are pasted below (from the first warning/error on) thanks again in advance Astrid > more mgmt_catalina.err Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase clearReferencesThreads WARNING: The web application [mgmt] appears to have started a thread named [Event bus] but has failed to stop it. This is very likely to create a memory leak. Stac k trace of thread: sun.misc.Unsafe.park(Native Method) java.util.concurrent.locks.LockSupport.park(LockSupport.java:175) java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(AbstractQueuedSynchronizer.java:2039) java.util.concurrent.LinkedBlockingQueue.take(LinkedBlockingQueue.java:442) java.util.concurrent.ThreadPoolExecutor.getTask(ThreadPoolExecutor.java:1074) java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1134) java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) java.lang.Thread.run(Thread.java:748) Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks SEVERE: The web application [mgmt] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1da78c7c]) and a value of type [org .python.core.ThreadState] (value [org.python.core.ThreadState@15402cf4]) but failed to remove it when the web application was stopped. Threads are going to be rene wed over time to try and avoid a probable memory leak. Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks SEVERE: The web application [mgmt] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1da78c7c]) and a value of type [org .python.core.ThreadState] (value [org.python.core.ThreadState@2cd2fdd8]) but failed to remove it when the web application was stopped. Threads are going to be rene wed over time to try and avoid a probable memory leak. Jul 26, 2020 3:58:44 PM org.apache.catalina.loader.WebappClassLoaderBase checkThreadLocalMapForLeaks SEVERE: The web application [mgmt] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@1da78c7c]) and a value of type [org .python.core.ThreadState] (value [org.python.core.ThreadState@7018c94]) but failed to remove it when the web application was stopped. Threads are going to be renew ed over time to try and avoid a probable memory leak. Jul 26, 2020 3:58:44 PM org.apache.coyote.AbstractProtocol stop INFO: Stopping ProtocolHandler ["http-nio-17665"] Jul 26, 2020 3:58:44 PM org.apache.coyote.AbstractProtocol destroy INFO: Destroying ProtocolHandler ["http-nio-17665"] Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Server version name: Apache Tomcat/9.0.36 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Server built: Dec 12 1969 11:45:33 UTC Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Server version number: 9.0.36.0 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: OS Name: Linux Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: OS Version: 5.7.8-200.fc32.x86_64 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Architecture: amd64 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Java Home: /usr/lib/jvm/java-1.8.0-openjdk-1.8.0.252.b09-1.fc32.x86_64/jre Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: JVM Version: 1.8.0_252-b09 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: JVM Vendor: Oracle Corporation Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: CATALINA_BASE: /opt/archappl-2020Jul20-1614-27MDT/mgmt Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: CATALINA_HOME: /usr/share/tomcat Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -XX:MaxMetaspaceSize=256M Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -XX:+UseG1GC Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Xms512M Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Xmx512M Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -ea Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcatalina.base=/opt/archappl/mgmt Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcatalina.home=/usr/share/tomcat Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.process.id=73885 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.process.parent=73884 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: -Dcommons.daemon.version=1.2.2 Jul 26, 2020 3:59:00 PM org.apache.catalina.startup.VersionLoggerListener log INFO: Command line argument: abort Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent INFO: Loaded Apache Tomcat Native library [1.2.23] using APR version [1.7.0]. Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent INFO: APR capabilities: IPv6 [true], sendfile [true], accept filters [false], random [true]. Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener lifecycleEvent INFO: APR/OpenSSL configuration: useAprConnector [false], useOpenSSL [true] Jul 26, 2020 3:59:00 PM org.apache.catalina.core.AprLifecycleListener initializeSSL INFO: OpenSSL successfully initialized [OpenSSL 1.1.1g FIPS 21 Apr 2020] Jul 26, 2020 3:59:01 PM org.apache.coyote.AbstractProtocol init INFO: Initializing ProtocolHandler ["http-nio-17665"] Jul 26, 2020 3:59:01 PM org.apache.catalina.startup.Catalina load INFO: Server initialization in [1,140] milliseconds Jul 26, 2020 3:59:01 PM org.apache.catalina.core.StandardService startInternal --More--(99%) ==================================== >sudo more arch.log 0 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Archiver Appliance Version 0.0.1_master_H649cc2a_B2020Jul15-2234-24MDT_T 5 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - 18 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - My identity is appliance0 and my mgmt URL is http://10.0.0.78:17665/mgmt/bpl 24 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archappl.properties using the environment/JVM property from /opt/archap pl/archappl.properties 32 [main] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading installation specific properties file from /opt/archappl/archappl. properties 177 [main] INFO config.org.epics.archiverappliance.config.ConvertPVNameToKey - The pv name components in this installation are separated by these characters [\: \-] and the key names are terminated by : 10183 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Post startup for MGMT 10444 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Setting my cluster port base to 16670 and using interface 10.0.0.7 8 11698 [Startup executor] INFO config.org.epics.archiverappliance.config.persistence.MySQLPersistence - Looking up datasource called jdbc/archappl in the java:/co mp/env namespace using JDNI 11698 [Startup executor] INFO config.org.epics.archiverappliance.config.persistence.MySQLPersistence - Found datasource called jdbc/archappl in the java:/comp/en v namespace using JDNI 11698 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading PVTypeInfo from persistence 11818 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder= ${ARCHAPPL_SHORT_TERM_FOLDER}&partitionGranularity=PARTITION_HOUR&consolidateOnShutdown=true java.nio.file.AccessDeniedException: /home/arch/sts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11820 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par titionGranularity=PARTITION_DAY&hold=2&gather=1 java.nio.file.AccessDeniedException: /home/arch/mts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11820 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti tionGranularity=PARTITION_YEAR java.nio.file.AccessDeniedException: /home/arch/lts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11821 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&part itionGranularity=PARTITION_HOUR&consolidateOnShutdown=true java.nio.file.AccessDeniedException: /home/arch/sts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11821 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par titionGranularity=PARTITION_DAY&hold=2&gather=1 java.nio.file.AccessDeniedException: /home/arch/mts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11822 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti tionGranularity=PARTITION_YEAR java.nio.file.AccessDeniedException: /home/arch/lts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11822 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=STS&rootFolder=${ARCHAPPL_SHORT_TERM_FOLDER}&part itionGranularity=PARTITION_HOUR&consolidateOnShutdown=true java.nio.file.AccessDeniedException: /home/arch/sts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11823 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=MTS&rootFolder=${ARCHAPPL_MEDIUM_TERM_FOLDER}&par titionGranularity=PARTITION_DAY&hold=2&gather=1 java.nio.file.AccessDeniedException: /home/arch/mts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11823 [Startup executor] ERROR org.epics.archiverappliance.config.DefaultConfigService - Exception parsing storage metrics url pb://localhost?name=LTS&rootFolder=${ARCHAPPL_LONG_TERM_FOLDER}&parti tionGranularity=PARTITION_YEAR java.nio.file.AccessDeniedException: /home/arch/lts at sun.nio.fs.UnixException.translateToIOException(UnixException.java:84) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:102) at sun.nio.fs.UnixException.rethrowAsIOException(UnixException.java:107) at sun.nio.fs.UnixFileSystemProvider.checkAccess(UnixFileSystemProvider.java:308) at java.nio.file.Files.createDirectories(Files.java:746) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.setRootFolder(PlainPBStoragePlugin.java:497) at edu.stanford.slac.archiverappliance.PlainPB.PlainPBStoragePlugin.initialize(PlainPBStoragePlugin.java:385) at org.epics.archiverappliance.config.StoragePluginURLParser.parsePlainPBStoragePlugin(StoragePluginURLParser.java:123) at org.epics.archiverappliance.config.StoragePluginURLParser.parseETLDest(StoragePluginURLParser.java:103) at org.epics.archiverappliance.config.ApplianceAggregateInfo.addInfoForPV(ApplianceAggregateInfo.java:46) at org.epics.archiverappliance.config.DefaultConfigService.loadTypeInfosFromPersistence(DefaultConfigService.java:1758) at org.epics.archiverappliance.config.DefaultConfigService.postStartup(DefaultConfigService.java:725) at org.epics.archiverappliance.mgmt.MgmtPostStartup.run(MgmtPostStartup.java:44) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) 11823 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 3 PVs from persistence into cluster 11823 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading aliases from persistence 11824 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 0 aliases from persistence into cluster 11824 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading archive requests from persistence 11825 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading 0 archive pv requests from persistence into cluster 11825 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Loading external servers from persistence 11825 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Done loading external servers from persistence 11831 [Startup executor] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Start complete for webapp MGMT 11831 [Startup executor] INFO config.org.epics.archiverappliance.mgmt.MgmtPostStartup - Finished post startup for the mgmt webapp 30432 [http-nio-17665-exec-4] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from RETRIEVAL 30509 [http-nio-17665-exec-5] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from ETL 30988 [http-nio-17665-exec-6] INFO config.org.epics.archiverappliance.mgmt.WebappReady - Received webAppReady from ENGINE 32133 [http-nio-17665-exec-6] INFO config.org.epics.archiverappliance.mgmt.MgmtRuntimeState - All components in this appliance have started up. We should be ready to start accepting UI request 32134 [http-nio-17665-exec-6] INFO config.org.epics.archiverappliance.mgmt.MgmtRuntimeState - Starting archive requests after an initial delay (in s) of 10 86192 [http-nio-17665-exec-5] INFO config.org.epics.archiverappliance.config.DefaultConfigService - Obtained policies location from environment /opt/archappl/ess_policies.py ---current port listing >sudo firewall-cmd --direct --get-rules ipv4 filter INPUT 0 -s 10.0.0.0/8 -p udp --sport 5064 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --dport 5065 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 5075 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --dport 5064 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --dport 5065 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --dport 5075 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 16670 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 17665 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 17666 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 17667 -j ACCEPT 0 -s 10.0.0.0/8 -p udp --sport 17668 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --sport 16670 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --sport 17666 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --sport 17665 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --sport 17667 -j ACCEPT 0 -s 10.0.0.0/8 -p tcp --sport 17668 -j ACCEPT Il giorno dom 26 lug 2020 alle ore 04:52 Abdalla Ahmad <Abdalla.Ahmad at sesame.org.jo> ha scritto:
-- Astrid Morreale
Staff Scientist Subatomic Physics Group. Los Alamos National Laboratory. astrid at lanl.gov
ANJ, 26 Jul 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
