Subject: RE: asyn TracMask + asynMotor : function=
From: "Pearson, Matthew R. via Tech-talk" <[email protected]>
To: John Dobbins <[email protected]>
Date: Mon, 27 Jul 2020 19:47:21 +0000
Hi John,
If you enter ‘asynReport, 10’ on the IOC shell it will printout all the parameter names (as well as all the parameter lists), eg:
Parameter 175 type=asynInt32, name=CONTROLLER_SSICAPABLE, value=0, status=0
Cheers,
Matt
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Monday, July 27, 2020 3:15 PM
To: [email protected]
Subject: [EXTERNAL] asyn TracMask + asynMotor : function=
All,
I am learning to use the EPICS support for the Galil motor controller.  When I use
asynSetTraceMask("myAsynPort",0,8)
I get output like this:
2020/07/27 14:59:23.327 asynMotorController:writeInt32:: axis=0, function=175, value=1
in the source code
int function = pasynUser->reason;
But I don't see how to go from function=175 to the parameter defined in the source header so that this message will mean something to me.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
asyn TracMask + asynMotor : function= John Dobbins via Tech-talk
Prev: asyn TracMask + asynMotor : function= John Dobbins via Tech-talk
Next: Re: Old-ish CAS issue Timo Korhonen via Tech-talk
Next: Re: asyn TracMask + asynMotor : function= Torsten Bögershausen via Tech-talk
