Subject: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message
To: Abdalla Ahmad <[email protected]>, Michael Davidsaver <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 5 Nov 2020 16:55:27 +0000
> Right now I can't get my machine to enable core dumps in order to view the gdb backtrace,
You don't need to enable core dumps.  You can run the IOC within gdb to start with, and then you just issue the backtrace command at the gdb prompt
gdb [path_to_IOC]
gdb> run st.cmd
[crash]
gdb> backtrace
Sent: Thursday, November 5, 2020 10:23 AM
To: Mark Rivers; Michael Davidsaver; [email protected]
Hi Mark
I meant is it possible to set the NORD field in asyn port driver? Right now I can't get my machine to enable core dumps in order to view the gdb backtrace, but I just found out that every time I request a large buffer, I get a received byte count of 1448 which is the maximum data size in a TCP packet. I'll try to handle such case and see what happens.
Best Regards,
Abdalla.
Sent: Thursday, November 5, 2020 6:15 PM
To: Abdalla Ahmad <[email protected]>; Michael Davidsaver <[email protected]>; [email protected] <[email protected]>
> Regarding EPICS waveforms, what I meant is variable length from the client side;
> For example I set a buffer size in a PV and based on that PV value I read a specific length so that a plotter for example reads data with that specific length only.
> Does NORD achieve this?
NORD controls the maximum number of elements that can be read from the record.  It is the number of "available" elements.  You can request fewer elements in a read requests as well.
> If yes, how does asyn access individual record's fields?.
I am not sure what you mean by that question.
Have you been able to get a gdb traceback of your access violation problem?
Sent: Thursday, November 5, 2020 9:46 AM
To: Michael Davidsaver; Mark Rivers; [email protected]
Hi all.
Buffer size is 48 because the device sends waveform data in lines so I read each line separately by reading 48 bytes, If I request ADC 200 for example I receive 200 lines where each line is 48 bytes. I even did a test where I used a buffer size of 1M to receive the full 20000 lines and still got the same error.
Regarding EPICS waveforms, what I meant is variable length from the client side; For example I set a buffer size in a PV and based on that PV value I read a specific length so that a plotter for example reads data with that specific length only. Does NORD achieve this? If yes, how does asyn access individual record's fields?.
Best Regards,
Abdalla.
Sent: Tuesday, November 3, 2020 7:18 PM
To: Mark Rivers <[email protected]>; Abdalla Ahmad <[email protected]>; [email protected] <[email protected]>
On 11/3/20 8:49 AM, Mark Rivers via Tech-talk wrote:
> -          I don’t think EPICS supports variable length waveform records.  You need to create the waveform record in dbLoadRecords with a size that is the largest you plan to use.  That is what areaDetector does with NDPluginStdArrays.
To clarify, waveform records have a _maximum_ size which is fixed
on initialization (eg. NELM).  Actually size (NORD) has long been
changeable at runtime in the range [0, NELM].
Some caveats about NORD==0 apply wrt. CA specifically (works fine with PVA).
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Abdalla Ahmad via Tech-talk
RE: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Michael Davidsaver via Tech-talk
Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Prev: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Next: Re: device support for Keithley 428 Current Amplifier Johnson, Andrew N. via Tech-talk
Next: Re: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Abdalla Ahmad via Tech-talk
