1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Can I open a CSS Phoebus layout from the command line
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Phillip A. Sorensen" <[email protected]>, "Kasemir, Kay" <[email protected]>
Date: Tue, 26 Jan 2021 13:28:57 +0000
>> I can open it from the Window->Open Layout menu, but I was wondering if
>> there is a way to open a layout from a command line parameter.  I would
>> like to create a wrapper that starts phoebus with the alarm layout.
>Right now there is no "-open_layout" type command line option, but you can do the following:
There will soon be this command line option:
-layout /path/to/Example.memento        -  Start with the specified saved layout instead of the default 'memento'
See https://github.com/ControlSystemStudio/phoebus/pull/1747
-Kay
Can I open a CSS Phoebus layout from the command line Phillip A. Sorensen via Tech-talk
Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Prev: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Next: RE: EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
