1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: EPICS Module mrfioc2
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 26 Jan 2021 13:30:36 +0000
Thanks Yong this should be helpful. Does it support specific firmware versions? We were using a custom driver but we found out that it was made for the older firmware E401, the spare parts we have we found out they are using the MRM (Modular register map) firmware (6 or 7 I think), so I wonder if the driver is handling firmware versions differences.
Best Regards,
Abdalla.
Sent: Tuesday, January 26, 2021 3:22 PM
To: Abdalla Ahmad <[email protected]>; [email protected]
Subject: Re: EPICS Module mrfioc2
Hi Abdalla, I think this is what you are looking for: https://github.com/KIT-IBPT/epics-mrf
Good luck!
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: Abdalla Ahmad <[email protected]>
Date: Tuesday, January 26, 2021 at 5:42 AM
Subject: EPICS Module mrfioc2
Hi
I came across this module https://github.com/epics-modules/mrfioc2 when searching for a driver for MRM-based timing system hardware. Looking at the source code it does not seem to work with Ethernet connected hardware, only VME. Our timing system hardware is inserted into a VME chassis but connected to the control system via the board’s Ethernet interface. Can this driver be configured to connect to Ethernet-connected hardware?
Thanks.
Abdalla.
Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
EPICS Module mrfioc2 Abdalla Ahmad via Tech-talk
Prev: Re: Can I open a CSS Phoebus layout from the command line Kasemir, Kay via Tech-talk
Next: Re: Python cothread errors Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
Next: Re: EPICS Module mrfioc2 Hu, Yong via Tech-talk
