1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: autosave -- NOWRITE pvs request
From: "Luchini, Kristi L. via Tech-talk" <[email protected]>
To: "Mooney, Tim M." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 29 Jan 2021 02:22:26 +0000
Hi Tim,
Thanks for such a quick response.
>For each database, we have an autosave-request file, and this will be used if no user-written request file is found.
So it seems like the only solution is to generate my ow list of pvs  by using the autogenerated file as my base.  I’d  perfer that the epics module/driver provide a “req” file, which could be installed by the application and edited, where the “req” file had the name of the database as you described.  However,  I’ve already made this request but it looksl I’ll need to do this for now in my application.
>I did not answer your question about a NOWRITE option because I'm not sure I understand exactly what you mean, and I haven't thought of a good place to put such an option.
Not important.. This is  feature we had with ChannelWatcher, where the “req” file provides 2 columns the left column the pvs to save and the right column an optional switch, one of which was “/NOWRITE”.  In the “sav” file monitored all the pvs but in the st.cmd file the restore load file only loaded those pvs from the “sav” file that did not have the “/NOWRITE” option in the “req” file.  It’s useful during the run to what pvs change in the “sav” file even if they won’t be restored, rather than traversing through displays you can do searches in the “sav” file using wildcards.   It’s not going to save me time though here.. I’ll just generate my own autosave files thanks very much for your help!!!
Best Regards,
-          Kristi
Sent: Thursday, January 28, 2021 5:24 PM
To: [email protected]; Luchini, Kristi L. <[email protected]>
Subject: Re: autosave -- NOWRITE pvs request
Hi Kristi,
This is one reason that we use autosaveBuild, instead of info fields, to allow a database developer to specify a default set of PVs for each instance of that database.  In some cases, it's essential for a database developer to be able to specify autosaved PVs, because the database depends on those PVs to restore its internal state.  In other cases a new version of a database needs a new version of the request file, and it's helpful for those files to be released together in a module version.  But sometimes an end user needs to override those choices, and autosaveBuild supports this with a directory list.
For each database, we have an autosave-request file, and this will be used if no user-written request file is found.  But request files are searched for in the order that directories that might contain request files were specified.  We often specify the IOC boot directory as one place request files might be found, and list it first so a file there will override the database developers default request file.
For example, these two commands:
    set_requestfile_path(startup, "")
    set_requestfile_path(area_detector, "ADApp/Db")
tell autosave to look in the IOC directory before looking in the areaDetector directory for request files, and this allows you to copy the request file from areaDetector, edit it to meet your needs, and place it in the IOC directory.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Luchini, Kristi L. via Tech-talk <[email protected]>
Sent: Thursday, January 28, 2021 6:17 PM
To: [email protected] <[email protected]>
I’m having the following issue using autosave, where my ioc application  includes a number of epics modules/driver, which use the info field on many pvs.  This means that the ioc application does not have  control over what is being saved, unless I override the pvs in my application.  Now in my application, I could save local pvs  in a manually generated  req file, and initially auto-generate the standard autosave files, edit those files and give them unique filenames and load these manually, not using the auto-generate feature. However, numerous application are going to use these modules/driver and will have the same issues and will need to duplicate this work. So I’d  like some way to turn off the save feature for some pvs in the “req” list.
For example:
If a “NOWRITE” option that could be set per pvs is available, then I could turn off the “info” field for select pv fields, so that the “req” file auto-generated would not include these pvs or would include them but comment them out, so that the monitor would skip those pvs.
Is this feature or is there another method that other have used to solve this same problem?
-          Kristi Luchini
Re: autosave -- NOWRITE pvs request Mooney, Tim M. via Tech-talk
RE: autosave -- NOWRITE pvs request Luchini, Kristi L. via Tech-talk
Prev: CS-Studio(Phoebus) Archive Viewer Matlab Export Issue Manoussakis, Adamandios via Tech-talk
Next: Re: autosave -- NOWRITE pvs request Mooney, Tim M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: autosave -- NOWRITE pvs request Mooney, Tim M. via Tech-talk
