1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: setcap and nosuid
From: Michael Davidsaver via Tech-talk <[email protected]>
To: "Siddons, David" <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Tue, 2 Feb 2021 11:39:26 -0800
On 2/2/21 10:49 AM, Siddons, David wrote:
> Well, everything works fine when running as root.
Ah, this is an important data point.  This brings us around to Linux capabilities.
It might be sufficient if you were able to set a file capability of CAP_SYS_RAWIO.
> I am just being encouraged to stop doing that 🙂
Sage advice.  And I should probably stop encouraging you to keep trying with /dev/mem then :)
> Pete.
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Tuesday, February 2, 2021 1:48 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS Tech-Talk <[email protected]>
> *Subject:* Re: setcap and nosuid
> On 2/2/21 10:09 AM, Siddons, David wrote:
>> Hi Michael,
>>    Setting 0666 doesn't help.
> Maybe your kernel doesn't have /dev/mem enabled either?
>> $ grep DEVMEM /boot/config-5.9.0-0.bpo.5-amd64
>> CONFIG_DEVMEM=y
>> CONFIG_ARCH_HAS_DEVMEM_IS_ALLOWED=y
>> CONFIG_STRICT_DEVMEM=y
>> CONFIG_IO_STRICT_DEVMEM=y
>> THanks for the link. I missed that before. It looks like the right way to go. I'll dig into it.
>> Pete.
>> *Sent:* Tuesday, February 2, 2021 12:13 PM
>> On 2/2/21 8:57 AM, Siddons, David wrote:
>>> Hi David,
>>> Yes, I saw that. Changing it doesn't seem to help:
>>> sudo chmod g+w /dev/mem
>>> ls -l /dev/mem
>>> crw-rw---- 1 root kmem 1, 1 Feb  1 21:05 /dev/mem
>>> ./regrw R 1   ( a program which maps the FPGA registers to userspace)
>>> Reading Register 1
>>> Can't open /dev/mem
>> Have you tried chmod 0666 to make sure this is really a permission problem?
>> The "Can't open" could also print 'errno'.
>> Also, I feel obligated to repeat myself in recommending against using
>> /dev/mem in any kind of long term solution.  There are safer ways
>> to grant access to specific MMIO ranges.
>> https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php> <https://epics.anl.gov/tech-talk/2020/msg02201.php <https://epics.anl.gov/tech-talk/2020/msg02201.php>>
Re: setcap and nosuid Siddons, David via Tech-talk
setcap and nosuid Michael Davidsaver via Tech-talk
Re: setcap and nosuid Michael Davidsaver via Tech-talk
Prev: Re: setcap and nosuid Siddons, David via Tech-talk
Next: Re: setcap and nosuid Siddons, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
