1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Multiple IOCs on one host Issue
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 19 Mar 2021 10:54:27 +0100
Return code 1 means that one of the commands in the script returned that error or the IP or broadcast addresses are found empty (= not matched correctly by the grep in line 16/17).
If you run the script manually (as root), does it also fail and return 1?
If you try to do manually what the script does (find out the IPv4 and broadcast addresses of the interface and make the iptables call), which step fails?
If the grep fails, look at the line that the 'ip' command returns. What would be the right _expression_ to match the addresses that are needed?
Cheers,
~Ralph
On Fri, 19 Mar 2021 at 06:18, Manoussakis, Adamandios <[email protected]> wrote:
Thanks Yong for the tips, yes that was a typo on the EPICS_CA_ADDR_LIST.
I have tried manually running Ralphs script (chmod 755) with sudo ifdown ens33 / sudo ifup ens33 to bring down/up the interface.  I am seeing the script exit returning 1 which seems like its never reaching the adding of the rules to the iptables.
jetson@ubuntu:/etc/network/if-up.d$ sudo ifup ens33
Listening on LPF/ens33/00:0c:29:c6:6f:a0
Sending on   LPF/ens33/00:0c:29:c6:6f:a0
Sending on   Socket/fallback
DHCPREQUEST of 192.168.252.132 on ens33 to 255.255.255.255 port 67 (xid=0x2a8e39b)
DHCPACK of 192.168.252.132 from 192.168.252.254
RTNETLINK answers: File exists
/sbin/dhclient-script: 8: /etc/dhcp/dhclient-exit-hooks.d/chrony: /usr/lib/chrony/chrony-helper: not found
bound to 192.168.252.132 -- renewal in 789 seconds.
run-parts: /etc/network/if-up.d/ioc exited with return code 1
Failed to bring up ens33.
I would assume the added broadcast rules from the script would show up in the list iptables -L -v if it ran successfully.
Chain INPUT (policy ACCEPT 143K packets, 110M bytes)
 pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy DROP 0 packets, 0 bytes)
    0     0 DOCKER-USER  all  --  any    any     anywhere             anywhere
    0     0 DOCKER-ISOLATION-STAGE-1  all  --  any    any     anywhere             anywhere
    0     0 ACCEPT     all  --  any    docker0  anywhere             anywhere             ctstate RELATED,ESTABLISHED
    0     0 DOCKER     all  --  any    docker0  anywhere             anywhere
    0     0 ACCEPT     all  --  docker0 !docker0  anywhere             anywhere
    0     0 ACCEPT     all  --  docker0 docker0  anywhere             anywhere
Chain OUTPUT (policy ACCEPT 92977 packets, 12M bytes)
Chain DOCKER (1 references)
Chain DOCKER-ISOLATION-STAGE-1 (1 references)
    0     0 DOCKER-ISOLATION-STAGE-2  all  --  docker0 !docker0  anywhere             anywhere
    0     0 RETURN     all  --  any    any     anywhere             anywhere
Chain DOCKER-ISOLATION-STAGE-2 (1 references)
    0     0 DROP       all  --  any    docker0  anywhere             anywhere
Chain DOCKER-USER (1 references)
Thanks again everyone for your input.
-----Original Message-----
Sent: Thursday, March 18, 2021 5:30 PM
To: Manoussakis, Adamandios <[email protected]>; J. Lewis Muir <[email protected]>
Cc: [email protected]
A few comments and suggestions:
1. You had a typo (I guess EPICS_CA_AUTO_ADDR means to be EPICS_CA_AUTO_ADDR_LIST) although the typo probably does not make a difference in your case.
2. As Mark River said in another thread, you really do not need to set EPICS_CA_ADDR_LIST on the IOC Host.
3.  Ralph's iptables trick is really the least invasive if you or your IT professional colleagues can make it work.
4. Since you have difficulty making the iptables-trick work, you could try this invasive and nasty method which I occasionally used for Lab tests (just for test, not good for massive production):
  1) on the Host 192.168.2.100, in the first IOC's startup script (st.cmd), add this line: epicsEnvSet("EPICS_CA_SERVER_PORT", "5066"). In the second IOC's startup script, add this line: epicsEnvSet("EPICS_CA_SERVER_PORT", "5067"). In the third IOC ...
Basically each IOC has its unique CA Server port instead of the default 5064. After an IOC starts up successfully, type "epicsPrtEnvParams" (or epicsEnvShow) under the EPICS IOC shell to verify your all kinds of EPICS_CA* settings.
  2) on the Client 192.168.1.50, do something like this: export EPICS_CA_ADDR_LIST=192.168.2.100:5066 192.168.2.100:5067 192.168.2.100:5068
Basically EPICS_CA_ADDR_LIST a list of Host:EPICS_CA_SERVER_PORT. Again, type "echo $ EPICS_CA_ADDR_LIST " to make sure the settings of EPICS_CA_ADDR_LIST is really what you expect.
This nasty method works for nasty networking.
Cheers,
Yong
On 3/18/21, 6:34 PM, "Tech-talk on behalf of Manoussakis, Adamandios via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Hi Lewis,
    Env Vars are
    Host setup
    EPICS_CA_ADDR_LIST=Client IP
    EPICS_CA_AUTO_ADDR=YES
    Client setup
    EPICS_CA_ADDR_LIST=Host IP
    I don't think the env variables are the cause in this case but I did try looking at the iptables --list and --list-rules after manually running Ralphs script with sudo and wasn't seeing the added rules from the script.  I would think its possible to manually sudo run the script to get them added but I am not that familiar with it.
    Sent: Thursday, March 18, 2021 3:02 PM
    Cc: 'Ralph Lange' <[email protected]>; [email protected]
    On 03/18, Manoussakis, Adamandios via Tech-talk wrote:
    > Setup is as follows:
    > Client 192.168.1.50
    > Client running caget PV1
    > Env variable CA_ADDR is set to the host ip and CA_AUTO is set to YES
    > Host 192.168.2.100
    > Host running 4-5 IOCs (script is in both of the
    > /etc/network/if-up/down.d folders and have been made executable) Env
    > variable CA_ADDR is set to the client ip and CA_AUTO is set to YES
    Those aren't the right environment variables.  You might be abbreviating the names on purpose, but I would recommend you state the exact names you're using so that no one has to guess what you mean, and also just in case you've got a typo in any of them.
    Lewis
Re: Multiple IOCs on one host Issue Heinz Junkes via Tech-talk
Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Jeong Han Lee via Tech-talk
RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
Re: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue Ralph Lange via Tech-talk
RE: Multiple IOCs on one host Issue Mark Rivers via Tech-talk
Re: Multiple IOCs on one host Issue J. Lewis Muir via Tech-talk
Re: Multiple IOCs on one host Issue Hu, Yong via Tech-talk
Prev: Regarding getting video from camera from BOY (CSS) Siddharth Vardhan Pratihast via Tech-talk
Next: Re: Multiple IOCs on one host Issue Heinz Junkes via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Multiple IOCs on one host Issue Manoussakis, Adamandios via Tech-talk
