1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Rate of change calculation
From: "Pietryla, Tony via Tech-talk" <[email protected]>
To: Donny Domagoj Cosic <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 29 Mar 2021 12:41:03 +0000
Donny,
You could change your calc record to this:
record(calc, "$(KEIT):CalcCurrent")
     field(SCAN, "1 second")
     field(INPA, "$(KEIT):Charge PP")
     field(CALC, "LA-A")
This would subtract the new reading from the last reading.
Anthony Pietryla
Principal Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
On 3/29/21, 7:33 AM, "Tech-talk on behalf of Donny Domagoj Cosic via Tech-talk" <[email protected] on behalf of [email protected]> wrote:
    Hi Marty and Mark,
    Thank you for your quick response.
    What Marty suggested makes sense. If the record is processes in INPA,
    than of course INPB reads the same value from the Charge record. Thank
    you for pointing that out.
    However, when I corrected this error as you suggested, the result was
    still always 0. Changing the order of NPP before PP should have solved
    this problem but it didnt.
    Using Marks suggestion of setting B to A after the calculation
    ("B-A;B:=A") works as expected and yields the correct result. This
    solves my problem, but I still dont understand why Marty's suggestion
    didnt work.
    Thank you,
    Donny Domagoj Cosic
      Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
    Dana 29.03.2021 13:48, Smith, Martin via Tech-talk je napisao(la):
    > Hi Donny,
    >  Because the Charge record is Passive scan and is being processed
    > (presumably) only by
    >  the calc record what you are saying makes sense. the calc record
    > processes the charge
    >  record first for link A using a PP link causing it to get a new
    > value, then it gets that new
    >  value again using link B without processing (NPP) the charge record.
    >  I think what you really want is this:
    >  field(INPA, "$(KEIT):Charge NPP") # Get the current value of Charge
    >  field(INPB, "$(KEIT):Charge PP") # Process charge record then get the
    > new value
    >  field(CALC, "B-A") # You may need to change this to A-B if you want a
    > positive value assuming the charge is always increasing
    >  You need to get the current value first then process the record to
    > get the new value.
    >  Marty
    > FROM: Tech-talk <[email protected]> on behalf of Donny
    > Domagoj Cosic via Tech-talk <[email protected]>
    >  SENT: Monday, March 29, 2021 6:35 AM
    >  TO: Tech-talk <[email protected]>
    >  SUBJECT: Rate of change calculation
    > Hello,
    >  I am trying to calculate the rate of change of a record using a calc
    >  record as follows:
    >  record(ai, "$(KEIT):Charge")
    >  field(DESC, "Measure Charge")
    >  field(DTYP, "steam")
    >  field("@devKeithley6514.proto measureCharge() $(PORT)")
    >  field(SCAN, "Passive")
    >  field(INPB, "$(KEIT):Charge NPP")
    >  field(CALC, "B-A")
    >  The calc record always returns 0. If I change the calc to B+A, to
    > check
    >  what is going on, I always get double the charge. It seems like the
    > PP
    >  and NPP are both returning the same value even though the actual
    > charge
    >  is changing. Any ideas on why this would be happening or suggestions
    >  would be greatly appreciated.
    >  Thank you in advance,
    >  Donny
    >  Donny Domagoj Cosic
    > Croatia
Re: Rate of change calculation Johnson, Andrew N. via Tech-talk
Rate of change calculation Donny Domagoj Cosic via Tech-talk
Re: Rate of change calculation Smith, Martin via Tech-talk
Re: Rate of change calculation Donny Domagoj Cosic via Tech-talk
Prev: Re: CS-Studio Databrowser historical data display Kasemir, Kay via Tech-talk
Next: Re: Phoebus lock down BOB Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Rate of change calculation Donny Domagoj Cosic via Tech-talk
Next: Re: Rate of change calculation Johnson, Andrew N. via Tech-talk
