1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Rate of change calculation
From: Donny Domagoj Cosic via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 29 Mar 2021 14:32:39 +0200
Hi Marty and Mark,
Thank you for your quick response.
What Marty suggested makes sense. If the record is processes in INPA, than of course INPB reads the same value from the Charge record. Thank you for pointing that out. However, when I corrected this error as you suggested, the result was still always 0. Changing the order of NPP before PP should have solved this problem but it didnt.
Using Marks suggestion of setting B to A after the calculation ("B-A;B:=A") works as expected and yields the correct result. This solves my problem, but I still dont understand why Marty's suggestion didnt work.
Thank you,
Donny Domagoj Cosic
 Institut Ruđer Bošković, Bijenička cesta 54, 10000 Zagreb, Croatia
Dana 29.03.2021 13:48, Smith, Martin via Tech-talk je napisao(la):
Hi Donny,
 Because the Charge record is Passive scan and is being processed
(presumably) only by
 the calc record what you are saying makes sense. the calc record
processes the charge
 record first for link A using a PP link causing it to get a new
value, then it gets that new
 value again using link B without processing (NPP) the charge record.
 I think what you really want is this:
 record(calc, "$(KEIT):CalcCurrent")
 field(SCAN, "1 second")
 field(INPA, "$(KEIT):Charge NPP") # Get the current value of Charge
 field(INPB, "$(KEIT):Charge PP") # Process charge record then get the
new value
 field(CALC, "B-A") # You may need to change this to A-B if you want a
positive value assuming the charge is always increasing
 You need to get the current value first then process the record to
get the new value.
 Marty
FROM: Tech-talk <[email protected]> on behalf of Donny
 SENT: Monday, March 29, 2021 6:35 AM
 TO: Tech-talk <[email protected]>
 SUBJECT: Rate of change calculation
Hello,
 I am trying to calculate the rate of change of a record using a calc
 record as follows:
 record(ai, "$(KEIT):Charge")
 field(DESC, "Measure Charge")
 field(DTYP, "steam")
 field("@devKeithley6514.proto measureCharge() $(PORT)")
 field(SCAN, "Passive")
 field(INPA, "$(KEIT):Charge PP")
 field(INPB, "$(KEIT):Charge NPP")
 field(CALC, "B-A")
 The calc record always returns 0. If I change the calc to B+A, to
check
 what is going on, I always get double the charge. It seems like the
PP
 and NPP are both returning the same value even though the actual
charge
 is changing. Any ideas on why this would be happening or suggestions
 would be greatly appreciated.
 Thank you in advance,
 Donny
 Donny Domagoj Cosic
Croatia
Re: Rate of change calculation Pietryla, Tony via Tech-talk
Rate of change calculation Donny Domagoj Cosic via Tech-talk
Re: Rate of change calculation Smith, Martin via Tech-talk
Prev: Re: Rate of change calculation Mark Rivers via Tech-talk
Next: Re: CS-Studio Databrowser historical data display Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Rate of change calculation Smith, Martin via Tech-talk
Next: Re: Rate of change calculation Pietryla, Tony via Tech-talk
