1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Array widget in Display Builder
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Tomasz Brys <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 14 Apr 2021 14:08:33 +0000
>So, If I want to have an EMPTY array of size 30 what I have to do?
>I do not want to change the size of this array. What I want is to write sometimes 3 elements, and sometimes empty it (keeping size of 30).
>Maybe I should use a Table widget instead?
We might mix our nomenclature when it comes to size/length/capacity.
For the array widget, they're all the same and fixed.
"Size 30" means there are always 30 elements.
'EMPTY' would mean no elements, size=length=0, while capacity may still be 30.
The array widget doesn't support that. You could set the array to [ 0, 0, 0, 0, ..., 0 ] with 30 x [0], but not EMPTY as in [].
Yes, for a display, you could use a table widget, but that requires a (small) script to transform the array data from the PV into the rows/columns of the table.
-Kay
Array widget in Display Builder Tomasz Brys via Tech-talk
Re: Array widget in Display Builder Kasemir, Kay via Tech-talk
Re: Array widget in Display Builder Tomasz Brys via Tech-talk
Prev: Re: Array widget in Display Builder Tomasz Brys via Tech-talk
Next: Re: problems with running EPICS Gateway on virtual machines? Ben Franksen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: CSS Display builder web runtime. Vishnu Patel via Tech-talk
