1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ...
Date: Tue, 20 Apr 2021 20:43:48 +0000
Hello everyone,
I am trying to build the latest asyn (commit a2da087) against base-R7.0.4.1, but encountered the same error “No rule to make target 'ipSNCServer.o'” as reported on tech-talk:
https://epics.anl.gov/tech-talk/2007/msg01045.php
However, I do have SNCSEQ defined in asyn/configure/RELEASE:
SNCSEQ=/usr/lib/epics
EPICS_BASE=/usr/lib/epics
As you see, both EPICS_BASE and SNCSEQ point to the same path in my RELEASE. This is the historical tradition at NSLS-2: we install all EPICS stuff (base, support modules) in a flat directory “/usr/lib/epics”.
$ ls /usr/lib/epics/
bin  cfg  configure  db  dbd  include  lib  startup  templates
This has been working well for base-3.14.12, meaning I can build the latest asyn (commit a2da087) against base-3.14.12 with SNCSEQ=/usr/lib/epics. Now, this kind of directory structure seems to not work for base-R7.0.4.1. I do see some warnings when building asyn against base-R7.0.4.1:
/usr/lib/epics/configure/RULES_BUILD:575: Warning: Base configure/RULES_BUILD file included more than once. Does configure/RELEASE have multiple pointers to /usr/lib/epics?
If I make a change like this: SNCSEQ=/home/yhu/epics/seq-2-2-6 where I have built “seq” in my home directory, I can build the latest asyn (commit a2da087) against base-R7.0.4.1 successfully.
So, the problem seems related to “Does configure/RELEASE have multiple pointers to …”. A simple search on Google/Tech-Talk does not give me any hints to fix the problem. Any suggestions are welcomed!
Yong
Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
Prev: Re: How to use asyGenericPointerSyncIO interface? Mark Rivers via Tech-talk
Next: Re: asyn: No rule to make target 'ipSNCServer.o'; Does configure/RELEASE have multiple pointers to ... Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
