1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: IOC unusable if no ethernet interface at startup
From: Markus Kristensson via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 26 May 2021 20:31:17 +0200
I have configured a Raspberry Pi 3 Model b+ to autostart and launch an IOC. The startup works fine if the RasPi is connected via ethernet to another computer. If the lan is not connected at startup, the IOC is basically unusable, responding to certain inputs, but extremely slow. If the ethernet cable is plugged back in, the responsiveness of the IOC is back to normal.
The RasPi will normally be connected to the other computer, but it is not necessarily so. I only need to control and access the IOC on the RasPi locally (i.e. on the Raspberry Pi itself). Do you have any suggestions how to proceed?
Cheers,
Markus Kristensson
Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Prev: Re: AreaDetector stream encoding Johnson, Andrew N. via Tech-talk
Next: New releases of areaDetector modules (ADCore R3-11 and others) Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: AreaDetector stream encoding Daykin, Evan via Tech-talk
Next: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
