1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: IOC unusable if no ethernet interface at startup
From: Markus Kristensson via Tech-talk <[email protected]>
To: [email protected]
Cc: [email protected]
Date: Thu, 27 May 2021 00:04:06 +0200
Hi again,
I've investigated the problem further. It turns out that I was too quick in judging that the IOC was starting up more or less correctly even when the ethernet cable was not plugged in. The reason for that conclusion was two-fold: 1. I ran the RPi in headless mode without any monitor connected. 2. The RPi did respond to change in some hardware, namely me changing a physical switch between two states. The response of changing the switch was seen in the opening/closening of a relay. As already stated, the response was very slow (sometimes around 10 s). What bugged me was that the same relay card did not open when a number of other DI:s received signal.
With a monitor connected I now realise that the IOC is actually NOT starting correctly when the ethernet cable is unplugged. The error is a BaseException with "No (specified) network interface(s) available". Interestingly, the plc (I run the ecmc-module) which handels the logic starts up briefly before the IOC startup is terminated. This gives enough time to read the input from the switch and to open up the relay, but not enough time for the other inputs to respond because of the logic using hysteresis (this is a solution for dealing with 14 cooling rooms and 2 cooling machines etc...). The slow responding time of the switch (max around 10 s) should then basically be related to the restart time of the IOC which I've configured using systemd to 10 s.
So, some things better understood, but my basic problem still remains. Do you have any suggestions of how I can resolve the problem of starting an IOC without it being connected to any network? I suspect I need to modify the startup script of the IOC, e.g. specifying EPICS_CA_ADDR_LIST to localhost. So far I have not been successful with such modifications.
Cheers,
Markus
2021-05-26 20:31 skrev Markus Kristensson via Tech-talk:
I have configured a Raspberry Pi 3 Model b+ to autostart and launch an
IOC. The startup works fine if the RasPi is connected via ethernet to
another computer. If the lan is not connected at startup, the IOC is
basically unusable, responding to certain inputs, but extremely slow.
If the ethernet cable is plugged back in, the responsiveness of the
IOC is back to normal.
The RasPi will normally be connected to the other computer, but it is
not necessarily so. I only need to control and access the IOC on the
RasPi locally (i.e. on the Raspberry Pi itself). Do you have any
suggestions how to proceed?
Cheers,
Markus Kristensson
Re: IOC unusable if no ethernet interface at startup Torsten Bögershausen via Tech-talk
IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Prev: New releases of areaDetector modules (ADCore R3-11 and others) Mark Rivers via Tech-talk
Next: Important Notice Regarding EPICS Collaboration Meeting Spring 2021 Glen Wright via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Re: IOC unusable if no ethernet interface at startup Torsten Bögershausen via Tech-talk
