1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: New releases of areaDetector modules (ADCore R3-11 and others)
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 26 May 2021 21:01:02 +0000
Folks,
There are new releases of a number of areaDetector modules.  These are the major items from each of the RELEASE.md files.
* ADSupport R1-10
  * Changed the support for reading MJPEG streams in GraphicsMagickSrc and xml2Src.
* ADCore R3-11
  * New plugin NDPluginBadPixel.
* ADGenICam R1-7-1
  * Fixed memory leak.
* ADAravis R2-2-1
  * Added continuous integration via Github Actions.  Thanks to Michael Davidsaver for this.
  * Improve error reporting by fetching the underlying error from aravis.
* ADSpinnaker R3-2
  * Updated Spinnaker version from 2.0.0.147 to 2.4.0.147.
* ADURL R2-3
  * Converted documentation to ReST, include in documentation on github.io.
  * Added autoconverted OPI files for css/BOY, css/Phoebus, edm, and caQtDM.
  * Fix to release the lock at least briefly between each image, otherwise EPICS puts don't get processed.
* ADViewers R1-7
  * Many enhancements to the Python PY_NTNDA_Viewer.
  * Updated to the latest versions of the EPICS Java libraries.
The home page is here:
https://github.com/areaDetector
The top-level documentation is here:
https://areadetector.github.io/master/index.html
Installation instructions are here:
https://areadetector.github.io/master/install_guide.html
areaDetector release notes are here:
https://github.com/areaDetector/areaDetector/blob/master/RELEASE.md
ADCore release notes are here:
https://github.com/areaDetector/ADCore/blob/master/RELEASE.md
Prev: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: IOC unusable if no ethernet interface at startup Markus Kristensson via Tech-talk
Next: Important Notice Regarding EPICS Collaboration Meeting Spring 2021 Glen Wright via Tech-talk
ANJ, 27 May 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
