1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Get timestamp from another IOC
To: "Johnson, Andrew N." <[email protected]>, Adrian Martinez <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 16 Jun 2021 16:00:59 +0000
Wow, good to know the fields of APST and MPST which seem specific to stringin / stringout.
https://epics.anl.gov/base/R7-0/5-docs/stringinRecord.html
These two fields are also available in base-3.14.12 (which is still being used at NSLS-2). But they are not documented in the old wiki “This Wiki is no longer being maintained”:
https://wiki-ext.aps.anl.gov/epics/index.php/RRM_3-14_String_Input
From: Tech-talk <[email protected]> on behalf of Johnson, Andrew N. via Tech-talk <[email protected]>
Date: Wednesday, June 16, 2021 at 11:39 AM
To: Adrian Martinez <[email protected]>
Hi Adrian,
On Jun 16, 2021, at 9:49 AM, Adrian Martinez via Tech-talk <[email protected]> wrote:
I've used 'dbr' command on IOC1 and this is the out for Timestamp_from_IOC1:
ioc > dbpr MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1 10
ACKS: NO_ALARM      ACKT: YES           APST: On Change     ASG:
ASP: (nil)          BKPT: 00            DESC:               DISA: 0
DISP: 0             DISS: NO_ALARM      DISV: 1             DPVT: 0x153cf30
DSET: 0x7f5fc4122160                    DTYP: Obj Prop string
EVNT:               FLNK:DB_LINK MBT-RBN:TMG-EVR-01:TimeErr-I
INP:INST_IO @OBJ=EVR-MTCA, PROP=NextSecond                  LCNT: 0
LSET: 0x1410530
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 85 50 01 00 00 00 00           MPST: On Change
NAME: MBT-RBN:TMG-EVR-01:Timestamp_from_IOC1   NSEV: NO_ALARM      NSTA: NO_ALARM
OVAL: Sun, 07 Feb 2106 06:28:16         PACT: 0             PHAS: 0
PINI: NO            PPN: (nil)          PPNR: (nil)         PRIO: LOW
PROC: 0             PUTF: 0             RDES: 0x1242bc0     RPRO: 0
RSET: 0x7f5fc3ca6560                    SCAN: 1 second      SDIS:CONSTANT
SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO            SIMS: NO_ALARM
SIOL:CONSTANT       SPVT: 0x1558ce0     STAT: NO_ALARM      SVAL:
TIME: 2021-06-16 14:47:16.997443401     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 1              UDFS: INVALID
The SCAN field is 1s, VAL field never changes but the TIME field of the PV does.
That explains why your source record isn’t getting a new timestamp then; the TSEL link actually sets up a CA monitor on the VAL field, so if that monitor never updates it will never get a new timestamp value.
If you set the MPST field of the above record to “Always” it will cause every process to generate a monitor update, which will update your other records.
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Get timestamp from another IOC Timo Korhonen via Tech-talk
Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Re: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Prev: Re: Re: Get timestamp from another IOC Hu, Yong via Tech-talk
Next: RE:FLIR camera bit depth configuration with ADSpinnaker BENEDETTI Florian via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Get timestamp from another IOC Johnson, Andrew N. via Tech-talk
Next: Re: Get timestamp from another IOC Timo Korhonen via Tech-talk
